Touring Fork Stop Diagram
Old Oct 21, 2019 | 07:05 AM
leafman60's Avatar
leafman60
Default Touring Fork Stop Diagram
Can anyone post a diagram or picture of exactly how the steering side to side stop system works on late model Touring bikes. The parts diagram implies this is all a part of the steering security lock design etc.
I haven't yet taken parts off to have a closer look.
Old Nov 17, 2021 | 02:55 PM
broke c7's Avatar
broke c7
did you ever find anything out on this? i need to look into that this winter when i work on my bike. i couldn't figure it out front the parts catalogue. so far The Google has not supplied answers either
and yes, i realize how old this is
Old Nov 18, 2021 | 08:17 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
The fork stops have nothing to do with the fork lock.
There are two tabs on the bottom side of the upper fork bracket, one on each side.
There is a tab on the top rear of the steering neck.
The parts microfiche is not going to show you this, you gotta stick your head in there an look, it is easy to see.
Old Nov 18, 2021 | 08:39 AM
broke c7's Avatar
broke c7
great, thanks. will be looking come January
Old Nov 18, 2021 | 08:44 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Here is where the tab is on the steering neck.
Old Nov 18, 2021 | 09:35 AM
NoRegerts's Avatar
NoRegerts
Here's a rough picture I made to try to explain what happens. The tab fits in a channel and when it hits the side of the channel as the bars are turned, it stops. The lock is a tab that blocks that channel when it is engaged.
Old Nov 18, 2021 | 11:45 AM
barneyboy's Avatar
barneyboy
Stop tab on steering neck.
Stop tabs on underside of top fork bracket.
Fork lock pin drops through this hole.
Into this hole.
Old Nov 18, 2021 | 05:51 PM
Dan89FLSTC's Avatar
Dan89FLSTC
The fork stop on a late model touring frame:
There is one tab in the center, on the rear of the steering neck.
There is a tab on the bottom of the upper fork bracket, one on each side.
When the forks are turned full lock, one of the tabs on the upper fork bracket will contact the tab on the rear of the steering neck.
The fork lock on a late model touring frame:
The fork lock mechanism on a late model touring frame is engaged by the ignition lock dropping a pin into a hole on either the left side or right side of the plate on the steering neck, depending on which direction the forks are turned.
This is how it is configured on late model touring bikes, which is what the discussion is about.
Here is an illustration pointing out one of the openings that the fork lock pin drops into:
Old Nov 19, 2021 | 07:02 AM
barneyboy's Avatar
barneyboy
There is only one hole for the fork lock pin. It's located on the right side of the neck as indicated in your illustration. The forks can only be locked in one position, which is full left.
Old Nov 19, 2021 | 09:22 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Thanks
rhacmebossier
Apr 8, 2017 06:29 PM
smalls78
Jan 12, 2016 06:07 PM
nedster
Touring Parts
Jun 25, 2013 08:35 PM
Peppa1
Touring Parts
Jul 25, 2012 05:24 PM
scarygt
Mar 28, 2010 06:18 AM
