A very simple adjustment and replacement of the link will cut your shifter linkage problems to a minimum. As I'm sure most know, replace your link ends with Kiem joints, they will not come apart. Second, does your linkage rattle or does it seem very loose and vibrate while bike is idling, that is what is wearing out the joints and splines. There is a rubber spacer between the shifter and primary case, it has to to compressed to put tension on the shaft and pull it tight so there is no play or slack and keeping your linkage from shacking itself apart. It also helps to keep everything lubed good including where the shaft goes through the primary case. Inspect every oil change and keep things tight and your linkage problems will go away.
There have been a number of revisions to the shifter lever. This is NOT the lever on the transmission. It's the lever you use with your foot/boot to shift gears.
HD Part Number: 33895-82E.
It includes the grade 8 socket head screw (5/16-18 X 3/4)
There are fixes for it. Cheapest is tightening it up before it comes loose. one would think that after having the same problem on one bike,you'd know enough to check it on subsequent bikes.
It is checked at service intervals. That doesn't prevent a failure, trust me.
OK,I'll trust you! I've owned 4 5-speed bikes,all high miles,the latest being my '06 with 103,000 on it. I've never had a shift lever failure on any of them.-I must be doing something right!
After reading through this and having experienced the problem first hand, I wonder how closely this issue is related to banging gears or a heavy heel.
I never had a problem with the transmission shift shaft or linkage on my forward control 2001 65K mile Dyna. It would get lose and I would tighten it up on occasion, but it never failed. However, it was a problem with my project 2003 Ultra. The lever splines stripped one afternoon in commuter traffic. I was able to pull over and crank down the torque enough to limp on home. It failed again as I was pulling onto my street.
I pulled the primary off and cleaned and dressed the shaft splines with a jeweler's file and put a new OEM lever on with a dab of blue Loctite on the bolt and torqued it to book specs. I also cleaned and dressed the forward control shift shaft and took off the heel shift lever because it was just to friggin' weird and unnatural after years riding the Dyna. That was around 5K miles ago and all is well.
I think one of the biggest issue with the splines stripping out is the heal shifter. I've watched many people stomp the living crap out of that thing. It's no wonder they get stripped. That said, HD should make them out of a harder material so they don't strip so easy.
People need to stop stomping the levers into gear like they're killing a cockroach. A light SNICK is all it needs. Then you can enjoy the first gear "clunk" more. I have posted before about the "snick" & yet people still tromp the SOB into gear. I see it all the time. Stop stomping; start snicking. And start appreciating the "clunk".
I believe they are designed to fail before damaging the much more expensive and complicated to replace transmission shift shaft. While it is softer than the shaft and prone to stripping, and may be a PITA to pull the primary to replace the lever, I do not believe a harder lever than OEM is necessarily the best answer for all applications.
