shifter shaft issue
Old Nov 3, 2019 | 11:27 AM
  #41
Keithhu's Avatar
Keithhu
Originally Posted by dickey
People need to stop stomping the levers into gear like they're killing a cockroach. A light SNICK is all it needs. Then you can enjoy the first gear "clunk" more. I have posted before about the "snick" & yet people still tromp the SOB into gear. I see it all the time. Stop stomping; start snicking. And start appreciating the "clunk".
I agree, although that might be more difficult than it seems, its much easier to use a light touch if you remove the heel shifter, which I always do. Except for my new bike, Harley took care of that for me.
Old Nov 3, 2019 | 12:28 PM
  #42
kel03's Avatar
kel03
Originally Posted by GOV5
NO. That would be the opposite of the cause. The heel part was the culprit. With the heel part removed, it should help, not hurt.
And you've got over 6000 posts here and you say you've NEVER heard of this issue? Really? How have you missed SO many threads on this? AMAZING!
Ha, was thinking it was the spine on the heel toe shifter ! Misread. Yep, heard of the shifter rod linkage issues, so get off my case, we're all entitled to a mistake, even after 6000 posts, lol. Have a good day pal.
Old Nov 3, 2019 | 04:15 PM
  #43
bowhunter97's Avatar
bowhunter97
Thanks for the information in this thread. I just saved myself some money today, after church I came home and checked my shifter linkage and it had some play but not as much as some. I tightened everything up and now little to no play. Thank you for posting.
Old Nov 3, 2019 | 04:41 PM
  #44
josame's Avatar
josame
I don't think it is mostly a problem of stomping. If you are using a regular allen wrench to tighten the pinch bolt, I don't think you can get enough torque on it to get it to spec. Use an allen that you can use with your wrench and you will see what I mean. I had this problem and when I bought a new shaft and arm the sales guy said they have been improved, that tells me the original material was designed to fail. Just think how much their service departments make fixing them. I was talking to my neighbor a while back, he has had a bike for probably 20 years and told me he has never changed his own oil. Can you imagine how much he has given the dealer in just oil changes. I know some people don't wrench and thats fine, it's whats is helping to keep the MOCO alive.
Old Nov 3, 2019 | 04:52 PM
  #45
TSheff's Avatar
TSheff
It is checked at service intervals. That doesn't prevent a failure, trust me.
Originally Posted by hdbob2006
OK,I'll trust you! I've owned 4 5-speed bikes,all high miles,the latest being my '06 with 103,000 on it. I've never had a shift lever failure on any of them.-I must be doing something right!
Never had it happen after I've owned a bike for a while, but I have repaired several after purchasing bikes.
First thing is if you feel any slack at all find it and fix it - you won't be caught on the side of the road.
Whether actual lever at the transmission, linkage (Heim joint), shift shaft on the primary, or foot shift levers, if the are properly tightened and maintained there will be no failures.
Another trick when the levers are removed on older bikes I widen the gap with a dremel tool and use an allen as mentioned before, allowing more torque and tighter fit.
Like Dickey stated - be a Snicker, not a STOMPER.
Just curious, those that have experience this failure, especially more than once, do you also have trouble finding neutral?
Old Nov 3, 2019 | 05:07 PM
  #46
nobodyknowsme's Avatar
nobodyknowsme
Originally Posted by corliss@bakerdrivetrain.com
If you are talking about the shift lever that loosens up and wallows out the hole, then we offer a beefed up version at baker:
https://bakerdrivetrain.com/products...nt=23522349379
It will hold up better based on our materials and finishing.
Don't guess you offer an extended length shaft? I have Cyclesmiths Banana Boards so have an extended length aftermarket shift lever on both bikes that I wouldn't mind replacing.
Old Nov 3, 2019 | 06:57 PM
  #47
rlh7677's Avatar
rlh7677
Sorry slip of the finger
Old Nov 3, 2019 | 07:01 PM
  #48
rlh7677's Avatar
rlh7677
Default mistake
Originally Posted by LQQK_OUT
It's called: heim
One of the many threads on heim joints.
https://www.hdforums.com/forum/touri...t-linkage.html
Slip of the finger, please forgive
Old Nov 3, 2019 | 07:41 PM
  #49
corliss@bakerdrivetrain.com's Avatar
We do not offer one. Sorry.
Old Nov 3, 2019 | 07:45 PM
  #50
I installed the Baker Shift Lever a few years ago on the 5-speed in my Fatboy to replaced the stripped out lever. Seems like a good product, but it is expensive.
I am curious why the part numbers seemed to change. I purchased part number: 3375-85SA-A
Why does your website call out part number: 33849-07HD-A for both 5 and 6 speeds now?
Yes, updated to accommodate for the newer stuff, 07 and up.
