If you only strap the bike with two straps, you are prepared only for the best case scenario.
If the truck and trailer are involved in a minor mishap, like taking an slight excursion off the road, that bike could be gone.
Don`t be complacent like the guy in the video, put some effort into it.
At least two in front, two in rear. Don`t expect the chock screwed to the plywood floor to keep the bike from shooting forward during an unexpected heavy deceleration, use two straps at the rear, pulling rearward, hooked to a beefy hold down point in the trailer.
And leave the Home Depot/Wal mart straps in the store...
Before i got the B&W Biker Bar, I used 4 ratchet straps in the front and 2 cam-lock straps at the back. It was rock solid.
The video link was to show how to properly use ties in the front.
The idea that the suspension being compressed during transport is going to damage the suspension is absurd.
When you are riding the bike the suspension is compressed...
Putting blocks under the frame is unnecessary, the bike does not need to be rigidly secured, it just needs to be secured properly.
It`s amazing how many big bikes you see on trailers, leaning on the side stand, with el cheapo (wal-mart / Home Depot) tie down straps.
You are correct it does not have to be rigidly secured, but what doing that does it help keep bike from doing any movement, movement that causes straps to stretch and loosen.. Eliminates the need to continually tighten up on tie downs on long trips. Just my findings over time
when i do have to trailer the bike, i load it on the trailer in a wheel chock and use soft loops around the handlebars and strap it down and compress suspension a little bit. I will also put two straps around a frame piece and pull it backwards. Also normally run a strap through the back wheel and wrap it around it twice and strap it down that way, the back end wont bounce up. I have never had a problem doing it this way.
Rigid is not secure? I guess we are getting into mine-is-bigger-than-yours posts now.
Ive never used blocks, but I have seen several bikes move around when the suspension wasnt completely compressed. If a good chock isnt used, the bike better be rigid, whether the suspension is compressed are not.
I tow a lot of different bikes and Harleys are easier than most with a lot of exposed frame for strapping. The best all-around way to secure most any bike on a trailer is a good wheel chock that will hold the bike up before straps are added.
