Motorcycle tie down
Old Nov 18, 2019 | 04:08 AM
  #31
S.D.M.F's Avatar
S.D.M.F
When i trailer my bike I use the B&W Biker Bar. No tie downs needed, no compressed forks. It holds my bike rock solid.
https://www.bwtrailerhitches.com/product/biker-bar
Old Nov 19, 2019 | 10:02 PM
  #32
koukey's Avatar
koukey
Invest in a Biker Bar, works great, no tie downs.
Old Nov 20, 2019 | 08:17 PM
  #33
sel53's Avatar
sel53
Have a look here ... this worked very well for me.
https://www.hdforums.com/forum/touri...with-pics.html
Use good tiedowns.
Old Nov 20, 2019 | 08:27 PM
  #34
sel53's Avatar
sel53
Originally Posted by threebyrds
If you use a tie down method that compresses the forks then how much do you compress them? Also do you put the bike in neutral or leave it in gear?
One inch. I mark it with painters tape on the forks so when it loosens up after a few miles I can set it back to 1”. I tried the “no compress” approach and it just wasn’t stable. This minimal compression really helps.
Not in gear, the bikes not going anywhere!
Old Nov 21, 2019 | 12:06 AM
  #35
threebyrds's Avatar
threebyrds
Thanks for your reply.
Old Nov 22, 2019 | 12:15 PM
  #36
Tallshooter's Avatar
Tallshooter
I use a Canyon Dancer in the front and strap to the passenger floorboard mounts in the rear.
Old Nov 22, 2019 | 05:07 PM
  #37
S.D.M.F's Avatar
S.D.M.F
If you're going to use straps....watch this:
Old Nov 23, 2019 | 06:56 AM
  #38
threebyrds's Avatar
threebyrds
That's how I have been doing it but Mister Harley advisor and Harley tech in Dallas said don't do it because the fender bolt will pull out. Not sure this way is actually pulling on those bolts unless it was bending the fork tubs.
Old Nov 23, 2019 | 07:08 AM
  #39
Bass Player's Avatar
Bass Player
I use ratchet straps just like anyone else. The method is individual preference. I try and keep the ratchet as low to the floor as I can. If a strap should break or come unhooked, the ratchet won't be so apt to be banging off the bike. I've seen that happen and it isn't pretty.
Old Nov 23, 2019 | 09:33 AM
  #40
Down South's Avatar
Down South
https://www.youtube.com/watch?v=YYR8QRq1L8c
That's what I do but I use a wheel chock too.
