Rebuild
Old Nov 26, 2019 | 07:21 AM
Neggy ZRXOA 5248's Avatar
Neggy ZRXOA 5248
The alternative to having your crank trued and welded,and everything magnafluxed, assuming the journals are in spec, is to use a S&S crankshaft, the down side it will run you $1300 dollars.
Old Nov 26, 2019 | 11:08 PM
Night Crawler's Avatar
Night Crawler
My philosophy has evolved over the years to, "if it ain't broke, don't fix it".
However, I would definitely do the lower end after increasing the bore size on the upper with 124k+ miles on the engine.
Also, if you decide to keep riding the "strictly adhered to maintenance" scoot, consider taking engine oil samples during oil and filter changes for a detailed oil analysis report. Any diesel engine dealer, CAT, Cummins, Detroit Diesel, etc..., offers them for less than 20-bucks and most have prepaid postage labels included. You'd be surprised all of the information one of those lab reports will tell you about the internals of your engine and oil properties.
Good luck.
Old Nov 27, 2019 | 05:58 AM
Screamin beagle's Avatar
Screamin beagle
I'd say with that many miles even with a mild rebuild you should take care of the bottom end. Call scott at hillside, that guy is a master at working with what you have and not upselling you on the biggest and baddest. Highly recommend hillside.
Old Nov 27, 2019 | 06:26 AM
Campy Roadie's Avatar
Campy Roadie
S&S doesn't make cranks for roller bearing Twin Cams (2003 and later). His left side case half would have to have a Timken conversion to work.
https://www.sscycle.com/tech-info/tech-tips/lower-end
Old Nov 27, 2019 | 08:50 AM
miner999r's Avatar
miner999r
Hopefully you don't have any metal in your oil. My bike lost power, oil had lots of bronze in it. This required a costly rebuild as the bottom end was thrashed.
Maybe get your oil to one of the oil analysis labs and see if your motor is showing signs of wear problems before you spend a lot? If everything is showing relatively normal than you get some peace of mind for a few bucks.
Old Nov 27, 2019 | 09:03 AM
skootchnc's Avatar
skootchnc
Originally Posted by Flyboy1958
I have a 2004 Road King with 124,800 miles on it......all by me. I feel like the engine may be getting weaker, and time for rebuild. Its not burning an ounce of oil between oil changes, and I will do a compression check to see how it is sealing. But, if the time has come, my question is whether or not I should touch the bottom end. I have used Screamin Eagle Synthetic in the engine, and HD recommended oil in primary and trans since after original break in, every 5000-6000 miles. My plan for top end is upgrade to 95 or 96 inch, from my current 88, using either SE or S&S parts. But as for the bottom end, my research shows that there are several vendors who do a decent job at the bottom end work including welding the crank to prevent shift, etc, and looking for recommendations. I could go another summer, and might, but eventually I want to do it before any catastrophic occurs. Thanks in advance.
HD long block program, is a very safe, and easy way to go....
but.... the engine will be "within tolerances".... where as you can (and IMO should) split the crankcase, and build your engine, from the ground up.
using top quality parts, and the difference between a rebuilt factory engine, and a balanced and blueprinted engine, isn't that great...
As long as you don't get into a "while I'm at it, I'll go ahead and do this too" phase.... which I got caught in.... but, now, I have a brand new 2005 FLTRi, for less money, than a downpayment, on a new bike
Old Nov 27, 2019 | 10:20 AM
hattitude's Avatar
hattitude
Originally Posted by grbrown
By all means simply continue riding it as it is, however if you decide to do any rebuild, even to stock tune, do start with the crankshaft. .
If/When you finally decide it is time to do the rebuild..... IMHO.....
If you are going to do the work yourself;
I would send the bottom out to DarkHorse CrankWorks and you will have a bullet-proof bottom end...
http://www.darkhorsecrankworks.com
Then do the top half of your choice (SE 95" or S&S 98") and with a good dyno tune, you'll be good for at least another 100,000 miles...
If you want a shop to do it;
Pick a good shop like Hillside that has been recommended here. Tell them what you want, and let them put together a package that will get you where you want to go..... Here is where a good shop, you can trust, is important.... a good shop won't push you into buying something you don't want, but may make a suggestion, that in their experience is critical to achieve your goals...
Enjoy
Old Nov 27, 2019 | 08:23 PM
Shovels & Vettes's Avatar
Shovels & Vettes
Default This
Enjoy
Yeah, I am not dropping the bike off at a shop and having them rebuild the engine. Too much labor that I can do myself. I will remove the engine from the bike, ship the lower end to someone, like Dark Horse, because no way I am dealing with that. Once I get it back, put it back in the bike, and the rest is just installing the cylinders, i.e. bored and honed cylinders with new pistons, possibly ship out the heads for valve job, ....in the end, it has to cost way less than any "long block" or new S&S. Its the beauty of being a mechanic for 40 plus years. Not everyone can nor should try it......but you have to know your limitations, and I have limitations. Sometimes its not worth spending money even on the special tools it takes. I have tools I used once for my Shovelhead, and my Corvette, that I will never use again.....so ???? Anyways, I am just trying to learn what is going on with these Twin Cam cranks that I need to deal with.
Old Nov 27, 2019 | 08:38 PM
99Birdman's Avatar
99Birdman
On my '02, I still had the good crank and, at your mileage, doing the top without the bottom was asking for trouble. Twin Cam cranks aren't anything special. 120K is still 120K.
As a mechanic for 40 years, I would think you would already knew the answer to your question but, if not, you've received as lot of good information here.
Good luck with your rebuild.
Old Nov 27, 2019 | 09:32 PM
Shovels & Vettes
Default Question
Being a mechanic for 40 years on airplanes, cars and motorcycles, means I have a given experience on those items,.....but does not mean I know everything about Twin Cam crankshaft problems. Which is my primary question in this thread. Looking for the expertise on this specific subject. I also know that not every "engine" wears out at 120,000 miles. Some do, some don't. Piston airplane engines have typical overhauls periods of 5000 hours. Turbine engine aircraft engines the same. How long a Twin Cam engine lasts may be different, and has alot to do with how it was used, or "abused", and now it was maintained over its life. So, without all this "mechanical" philosophy, my simple quest is to get some idea of whether or not 120,000 is time to rebuild a bottom end of a 2004 Road King Twin cam engine.
