LED lights causing radio interference !
Old Feb 10, 2020 | 05:48 PM
nobodyknowsme's Avatar
nobodyknowsme
Originally Posted by Bowhunter61
I have Custom Dynamics all around the bike, except for a Truckllight LED headlight and have absolutely no problems
This is because you get what ya pay for. I ran knock off Halo lights on a Road Glide and could not listen to radio for the interference. Now with Custom Dynamics, not a problem.
Old Feb 10, 2020 | 09:18 PM
TheMurf's Avatar
TheMurf
Default LED lights
I have LED headlight and spot lights, no Interference with the radio. Installed the LED turn signals, the best made, without naming the manufacturer as they are good folks and tried very hard to solution the issue. It was the turn signals that cause the radio Interference when you activate them. Maybe shielding would help ? In my cause I don't want to attempt to resolve, because once I take the lights out of the dealership they will not allow a return..I wanted them to install the lights, which they did and could not resolve.. Hopefully I will be able to take the bike directly to the light manufacturer to see if they can. The bike is a 012 model year FLHTCU.
Old Feb 10, 2020 | 10:25 PM
otto.maddox's Avatar
otto.maddox
I bought the $59 led headlight off Amazon.
It interferes with the radio somewhat. I don’t listen to the radio enough to care.
If I cared I’d buy a higher quality lamp from a place with a liberal return policy. If the new light caused interference I’d return it and try another one.
Old Feb 14, 2020 | 01:31 PM
JD Holbrook's Avatar
JD Holbrook
Default Led interference update
I think i found the problem!
I was bored so went to the garage to try to figure out this LED lighting problem,so i pull the headlight to put in bulb ,one more time. Applied bulb same as i did before. But before putting it back in housing ,i tried it by turning key on, and to my surprise ,no static came through speakers. So looking inside fairing ,through headlight bucket ,i see a bright red light. The previous owner must have installed a hidden powered antenna, that i was unawear of.
So wires from headlight bulb were actually laying ON the antenna, causing my problem.
sometimes its the simple things we ,or I , overlook.
Thanks to all ,for your help !
Old Feb 14, 2020 | 01:35 PM
Bowhunter61's Avatar
Bowhunter61
Well there you go!
Congrats on finding the issue, like you said sometimes it's the simple things you kind of overlook.
Old Feb 14, 2020 | 03:08 PM
cprhed's Avatar
cprhed
Good for you!, Sometimes all it takes is to step away and come back later.
Old Feb 14, 2020 | 09:08 PM
Trucky911's Avatar
Trucky911
Originally Posted by JD Holbrook
im considering adding the ferrites , but also had people tell me that they added , and did not help
Yep, did not help me...
Trucky911
jmeyer58
Electrical/Lighting/Alarm
Apr 28, 2023 03:34 AM
Papabear77
Sep 25, 2016 06:50 PM
coujac
2014-2024 Touring Models
Mar 17, 2016 04:08 AM
2010 Glide Rider
Oct 27, 2013 07:29 PM
GlennsGlide
Jul 15, 2007 06:33 PM
