If it's running good...put it back in. It looks to be within normal limits. That one looks like it's from the front cylinder. Don't be surprised if the rear plug looks a little whiter, more lean. Normal.
Actually, that plug came from the rear cylinder.
I have a PCIII with V&H true duals and oval slipons / stage 1 / SE air filter.
I've gradually adjusted the PCIII over the past year, until the decel popping stopped, while adding quite a bit of fuel compared to the stock map.
Does the plug look "rich"?
I'm only getting about 35mpg in the city, of course 40ish on the highway
