High speed question
Most of my riding is a mix of highway and back roads. I rarely run over 80 mph except for brief periods to pass or just have some fun. But I do like to twist the throttle and get up to speed quickly. I'm sure I could get a little better mileage if that was my goal.
Riding on the interstate across Utah and Colorado where the speed limit was 85, I rode 95-100 just keeping up with what little traffic there was. High speed and high altitude combined to drop my mpg under 30.
Of course a motor can lug, but lugging is not based on RPM, lugging is when the pressure in the cylinders is to low for the load (bike weight) on the engine.. The rider can test for lugging by adding 2/3s throttle; If the bike accelerates immediately, the motor isn't lugging. If acceleration is sluggish at best, the rider needs to downshift.
Beary
- That particular fill up took just under 2 gallons.
- The trip meter had like 107 miles on it when I filled in Spearfish. (107/2= 53.5 mpg)
- Gassed at Conoco on US-16 near Rushmore Shadows.
- Left next AM from Hart Ranch.
- Rode thru Rapid, out Nemo Road to Vanocker Canyon Road to Sturgis to Boulder Canyon Road to Deadwood to Central City to Lead to Cheyenne Crossing, north on Alt US-14 thru Savoy to Spearfish, then filled up at Exxon at Jackson & N Ames after lunch at Sanford's.
- The fill up was because the ride home was via I-90 running 75 mph.
- The ride home always drops mileage to around 32-42 mpg depending on wind.
And I also said on the way home (which is Hart Ranch, my summer home when in SD, where I began that ride). Never said home to Michigan. You misunderstood my post: sorry I wasn't clear. On I-90 at mile 12, off I-90 at mile 63. That (roughly) 50 miles at 75 mph can use most of the fuel left in the tank w/o the top off in Spearfish if the winds are blowing strong (hence my reference to wind in my 2nd post). SD often sees winds of 40 to 50 mph on that stretch of highway.
As for normal, every day riding here in Michigan, when I fill up, the "range to empty" values will display from around 210 miles to 270 miles, depending upon highway, 2 lane & city riding mix. Never the 300 miles plus I get every time I ride that route in SD.
I try to ride using minimal twist of the throttle to accelerate with traffic; I consider this conservative riding. I can jump on the throttle when needed, but find the minimal throttle movement riding method with fluid, smooth shifts more challenging than the way I used to ride, wicking the throttle & shifting hard. Granted, the latter method is generally more fun, but the former is more challenging for me & provides me with a sense of accomplishment. Maybe too many years serving as a HOG Chapter Safety Officer? IDK?
Please don't think I'm trying to have a pissing match. Was not & is not my intent.
Ride Safe!
When I look at my Range indicator, I am reminded of the Investment Firms' disclaimer of Mutual Funds performance: "Past history is NOT indicative of FUTURE performance."
That range estimate is a calculation off how you have been riding over the past miles. I don't know how many miles it uses, or how many tanks it uses in calculating the range. You will notice the range is different each time you fill up, unless you are riding at the same speed all the time, like you might do on a long Interstate trip. At least, this is what I've noticed.
Beary
I think it's pretty obvious, without a scientific study, that how your ride, where you ride, and the speeds you ride, can cause quite a variance in MPGs on the same bike.... I've found that to be true on all my vehicles...
I try to pay attention to the MPGs my bikes get. It helps me plan fuel stops when I take a trip. Additionally, if I'm riding an unknown area with no planned fuel stops, it lets me know how far I can go before I really need to get some fuel..
Those "mileage to go" counters can be quickly influenced by your right wrist....
My Ultra gives between 37 and 42mpg, all depends on the right hand. I'm sure it can get better but I like to move.
