Stupid question?
Old Mar 29, 2020 | 01:14 PM
Coptermd's Avatar
Coptermd
6th Gear
Angry Stupid question?
OK I have 2012 FLHTCU 96 in. Every couple years I need to replace the intake seals which sound odd but Iv gotten used to it. Here is the problem. I remove the fuel injection control unit , Unplug 4 pugs and one fuel line replace the seal like I have three times in the past but this time when its all back together . when I start it revs like crazy I can usually shut it down by 3500 RPM or so but I have checked everything I can think of. Out of ideas…anyone ?
Old Mar 29, 2020 | 01:31 PM
FPV's Avatar
FPV
Thy this and if it doesn't work do a search for "throttle reset".
Throttle by Wire High Idle Reset For Harleys. To reset your idle setting back turn the ignition switch on for 10 seconds off for 10 seconds (do not start the engine), repeat a total of 4 times. That should reset your original throttle position.
Also, a 96" in a 2012 Ultra?? Thought all touring had a 103" by that year. Learn something new everyday I guess?
Old Mar 29, 2020 | 04:36 PM
Coptermd's Avatar
Coptermd
6th Gear
Throttle reset procedure produced no change in symptoms., Still wraps like its wide open. on the positive side it sounds like the intake leak is fixed!
Old Mar 29, 2020 | 04:40 PM
MattD118's Avatar
MattD118
IMHO, I'm certainly no expert but it definitely sounds like you have an intake leak sucking air from somewhere. Maybe try spraying some carb cleaner around to try and isolate it.
Old Mar 29, 2020 | 04:41 PM
FPV's Avatar
FPV
Run/Stop switch in the on position when preforming reset procedure? If so, then check pins inside of plug that connects to throttle body. Make sure nothing is bent inside of plug and that pins are clean.
Old Apr 7, 2020 | 03:50 PM
Geoff1200's Avatar
Geoff1200
My VERY high mileage FLHTC did that, found the throttle body shaft had broktificated....
Old Apr 7, 2020 | 03:53 PM
Super Glidester's Avatar
Super Glidester
you mean "broke-ulated?" Cross thread points!
Old Apr 7, 2020 | 04:00 PM
smitty901's Avatar
smitty901
2012 all touring bikes were 103 . 2011 it was standard on the RGU and an option on the others. But in 2012 all Touring went 103.
steves86ta
Dyna Parts
Apr 28, 2015 11:54 AM
FlyBD5
EVO
19
Feb 17, 2013 01:26 PM
the_cruz
Dec 12, 2012 07:08 AM
parrothead306
May 7, 2009 04:52 AM
lowrider19661974
Sep 9, 2008 08:05 PM
