Legends ARC settings
Old Apr 15, 2020 | 01:08 PM
royston's Avatar
royston
Default Legends ARC settings
Just wondering what others had found most comfortable.
I installed the 13” Arcs and the Axeo standard at the same time.
for Rebound and compression I set at 5 and 5 assuming position 0 is furthest clockwise. Having done several runs with each setting changed in increments i found this was best for me at 175 lbs.
Anyone done similar?
Cheers
Old Apr 18, 2020 | 10:55 AM
TXCHOP's Avatar
TXCHOP
Installing my setup this week. Bumping this up to get more views/opinions.
Did you mount the resi high or low?
Old Apr 18, 2020 | 11:53 AM
royston's Avatar
royston
I mounted mine lower, on the bag supports....TBH mounting that canister there was possibly the most difficult part of the whole job......Are you doing front and Rears? Keep us in the loop and good luck
Old Apr 18, 2020 | 04:31 PM
TXCHOP's Avatar
TXCHOP
I went low as well. I like them mounted up high, but figured i would get tired of the look.
The fronts are going in next week when i get some time. Took me about an hour to do the rears. Long ball allen is the trick with the small screws. lol
Old Apr 19, 2020 | 02:20 AM
royston's Avatar
royston
When you can speak of that Allen you know you have been there lol - a pig eh?
Keen to hear your thoughts when done,
Settings for rear /settings for front (mine is at “0”) / and thoughts on the new riding geometry...to me a bit of getting used to for familiarity .....
TheOtherJoseph
Audio Systems
Apr 4, 2017 07:46 PM
tubeman426
Audio Systems
28
Aug 17, 2013 07:49 PM
Buff58
Aug 1, 2013 10:00 AM
springer 03
Audio Systems
Jul 22, 2013 05:44 PM
The Q
Audio Systems
May 8, 2013 06:38 AM
