brake light fuse
Old Apr 26, 2020 | 01:41 PM
sidewalkman's Avatar
sidewalkman
Default brake light fuse
Hi Everyone, for some reason the lighter stopped working, also the brake lights. I'm thinking fuses but I checked the small fuse block under the right cover and they're fine. I just changed out a bulb in the tourpak that was blown.... Am I missing something?
Old Apr 26, 2020 | 02:24 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Replace the accessory fuse and see...
Old Apr 26, 2020 | 07:36 PM
dawg's Avatar
dawg
How did you check the fuses, visually or with a tester? Use a tester as visually can be deceiving. As stated above, check the P&A fuse.
Old Apr 26, 2020 | 10:26 PM
dafrisco's Avatar
dafrisco
Check the fuses on the left side under the panel.
Old Apr 26, 2020 | 11:31 PM
sidewalkman
Found it, blown acc fuse, lighter fell out on the road, I got a new one, complete kit and it was grounding. Fixed the ground and alls good, thanks for all the replies.
hdarmy64
May 2, 2021 05:54 PM
Hades02
Electrical/Lighting/Alarm
16
Oct 19, 2017 04:27 PM
BigEasyRyder
Apr 9, 2013 08:08 AM
sliceball
Mar 2, 2009 12:43 PM
aped06classic
Mar 15, 2008 11:44 AM
