New to Harley, getting 2020 RGL -- What should I know?
Old May 14, 2020 | 03:46 PM
  #41
Omega2k5's Avatar
Omega2k5
Originally Posted by 95th 1200
Don't lug the engine (<2500 RPM). These things make a lot of torque, combined with the rubber mounting and balance system it's easy to let the RPMS fall too low without feeling it. If in doubt rev it up, the M8 enjoys what some deem to be high RPMs. If you wont be riding it for more than 2 weeks the use of a battery maintainer is a must, so much so that the lead is prewired in from the factory and should be routed during setup to be accessible. When checking the oil make sure it's in the middle of full and add, people who fill them to the absolute full mark quickly learn that by doing that you'll end up with oil dripping from the air cleaner - It's not indicative of a problem, just a characteristic.
Very cool, thanks for this info.
Also, where is the battery tender lead located? They just kind of dropped the bike off, picked up my trade and took off.
Old May 14, 2020 | 04:33 PM
  #42
95th 1200's Avatar
95th 1200
It will *usually* be between the seat and saddlebag on either side, however some dealers do weird stuff and tuck them under the side covers or things like that. Best bet is to contact your salesperson, they'll know or can get the answer - generally dealers will set up all the bikes the same way so it will be easy for them to figure out.
CaffeineBuzz
Screamin Eagle CVO Models
23
Jun 12, 2020 04:26 AM
T^2
Jan 4, 2017 11:58 AM
mgardner
Welcome Area Only
20
Feb 25, 2014 09:57 PM
The Tin Man
Feb 23, 2010 09:03 AM
hollywood1959
Jun 13, 2009 10:03 PM
