True-Track install tips
Old May 11, 2020 | 10:15 PM
1993FXSTS's Avatar
1993FXSTS
I was able to get the front mount installed tonight. The washer for the nut under the oil filter was in a recess in the mount where I couldn't see it. I took it out and was just able to install the bolts. Hopefully it won't rain tomorrow and I can get a ride in to check out the improved handling.
Old May 11, 2020 | 10:32 PM
23Seven's Avatar
23Seven
Glad you got it worked out.
Old May 28, 2020 | 01:54 PM
1993FXSTS's Avatar
1993FXSTS
Just wanted to follow up and close out this thread. The mods made a big improvement in the cornering stability of the bike. It used to feel like it had really bad swing arm pivot bearings in and the swing arm was moving side to side. The True Track front and rear stabilizers took all of that out. I'm certainly no road racer and I don't "drag pegs", but I now know that it will hold whatever line I choose in a corner. It was bad enough that I was seriously considering selling the bike. Now that I'm going to keep it, time to dump several thousand into it!
Old May 29, 2020 | 02:21 AM
23Seven's Avatar
23Seven
Have you changed suspension yet? That along with TT is amazing.
Old May 29, 2020 | 12:22 PM
1993FXSTS's Avatar
1993FXSTS
That is on the short list. There are so many options that have been discussed here on the forum. The guys name escapes me now, but the one who specs the Ohlin? shocks to you and your bike seems like the way to go. I'll also do the front end, to include chrome lowers. Woods 222 cams and a tuner from Fuel Moto are on the short list too.
Old May 29, 2020 | 01:04 PM
sanman4ever's Avatar
sanman4ever
Howard at Motor Cycle Metal is who you are referring too. After many different set ups my current suspension set up has been much improved from stock. I'd like to install the front stabilizer not sure it will fit with my Jagg Oil Cooler.
tjcaron
Audio Systems
May 28, 2019 03:25 PM
Linearms
Jun 15, 2016 03:32 PM
Mike Horrell
Apr 20, 2012 07:51 AM
Bryan TTM
Jul 8, 2006 12:24 AM
Unibomber
Feb 6, 2006 02:47 AM
