need some experienced advice
Old Jul 23, 2007 | 07:47 AM
harley_504's Avatar
harley_504
Default need some experienced advice
i have a 04 FLHTI. with a ticking/rattling noise at all speeds. took it to the stealer and he said that the muffler clamp was positioned wrong. so i left and 2 miles down the road quess what starts again. anyadvice is helpful thanks.
Old Jul 23, 2007 | 08:11 AM
Peekaboo Bob's Avatar
Peekaboo Bob
Default RE: need some experienced advice
Listen for it at idle. Put your hand (with gloves on) on the exhaust pipes. If it stops, look at the rubber bushings that the pipes are mounted to under the saddlebags. Mine makes noise there, and I stopped it by lubricating the rubber with a product called Super Lube. It's a synthetic grease thats good to temps up to 475 degrees. Also check all the heat shield clamps. One of them may be loose and rattling.
Spider0408
Aug 29, 2018 04:39 PM
Dspeziali
Exhaust System Topics
Apr 6, 2013 06:17 AM
Rocko Rock
EVO
Apr 19, 2009 10:39 PM
gunrunner
May 3, 2007 04:08 AM
SamStone
Jul 21, 2006 01:39 AM
