lower fairings for pre-rushmore vs rushmore..
Old May 17, 2020 | 06:54 PM
memphisharley's Avatar
memphisharley
Default lower fairings for pre-rushmore vs rushmore..
will the Rushmore lowers fit the pre 14 without modification.
thanks
Old May 17, 2020 | 07:05 PM
WoodButcher66's Avatar
WoodButcher66
I know I put a set of lowers off of a 2012 on my 2015 street glide. So I would assume you could go,the other way
Old May 17, 2020 | 07:08 PM
99Birdman's Avatar
99Birdman
thanks
Depends on model and year. FLH based bikes should be no problem. FLT bikes had a fairing mount change in 2005 or 2006 (not sure which) which can create clearance problems with trying to put newer lowers on older bikes.
Also, there were a few fairing mounting brackets on 2000-2004 era FLTs that were different from others (a screw hole in the fairing bracket for the lowers vs. a clamp).
Which model/year are you trying to make work.
Old May 17, 2020 | 07:26 PM
memphisharley
2012 rg
Old May 17, 2020 | 07:43 PM
woodreaux's Avatar
woodreaux
I liked the vented lowers on my 2013 Ultra better than the lowers on this 2019 Ultra Classic. I have had several problems with the push to open door latches and issues with the sliders for the vents.
With the earlier lowers you could get the magnetic covers or locking covers. I like having lowers and keep them on year round.
Old May 17, 2020 | 08:44 PM
99Birdman's Avatar
99Birdman
2012 rg
They should work no problem.
Old May 17, 2020 | 10:30 PM
Buelligan666's Avatar
Buelligan666
I bought Fairing Factory 14-up lowers and installed them on my 2012 FLTRXSE. I did a little write up.
https://www.hdforums.com/forum/touri...l#post15329579
Old May 17, 2020 | 10:57 PM
Jed Clampett's Avatar
Jed Clampett
I have both sets, for my 2020 FLHT. Both fit and both are sitting in the attic. I can't do lowers in the warmer months. They'll fit. I even made a set fit my Dyna.
Old Feb 21, 2024 | 10:57 AM
Crash546's Avatar
Crash546
Stage I
Im clearly late to the party but new to the site...
I am on an 04 EG Standard and looking at putting Rushmore lowers on mine. Anyone have any luck on putting the Rushmore on a model that far back?
Old Feb 21, 2024 | 11:09 AM
smitty901's Avatar
smitty901
Different frames . it would like take a lot of mods to make it right.
