Magneti Marelli EITMS system issue
Old May 30, 2020 | 08:50 PM
Michael Bazinet's Avatar
Michael Bazinet
6th Gear
Default Magneti Marelli EITMS system issue
Hi Guys I have a 1999 Road King Classic seems the rear cylinder is running cold (the bike is stone cold) and at start up the rear cylinder runs cold and the bike sputters at bit at mid to low throttle
however the bike pulls just fine. I suspect the engine temp sensor may be bad, Plugs are both clean and show no sings of fouling rear has spark Im thinking its a fueling issue.
Any ideas ?
Old May 31, 2020 | 09:51 AM
twistedcherokee's Avatar
twistedcherokee
Use a propane torch ( don't light it) stick it in the throttle body & open the torch up. if it smooths out, it could be the injector or a wiring issue. I had an injector go bad on my 99 Ultra a few years back, put 2 new ones in & had one of the new ones go bad a few months later. So I have an old one & a newer one in my bike. But my mileage has dropped & running black smoke on the left bank (cyl1 rear cylinder) so it may be time for some new ones again for me. But I have 130K miles on it.
Toby
Old May 31, 2020 | 06:36 PM
Michael Bazinet
6th Gear
Default 1999 road king M&M injection issue
Thank you very much I will give this a try where did you order your replacement injectors from ?
Thanks Michael
Old Jun 4, 2020 | 07:45 AM
twistedcherokee
it was several years ago from Bike Bandit, but I think they stopped carrying HD parts. I have done a search & have found nothing. But it uses what they call a side fill vs a top fill fuel injector. I am looking into some alternatives. Some Toyota's, Nissan's and Subaru's use the side fill. so it is a matter of the dimensions and flow rate. I hope to find out more since I think I may have to replace mine again, or at least the one with 130K miles on it.
Toby
Old Jun 4, 2020 | 08:22 PM
Michael Bazinet
6th Gear
Should you need them again I found them today and have 2 new ones on the way very difficult to find Let me know i will send you the company name
Do you know where I can find a TPS sensor for this bike I keep coming up empty
Thanks !
Old Jun 5, 2020 | 07:48 AM
twistedcherokee
Not as yet but I would like to get that info from you on the injectors.
Toby
Old Jun 7, 2020 | 03:16 PM
Michael Bazinet
6th Gear
Hi I got them at SouthBay Fuel Injection in NY State: https://www.southbayfuelinjectors.co...SAAEgKnWPD_BwE
Old Jun 7, 2020 | 09:50 PM
95th 1200's Avatar
95th 1200
Intake seals are probably on their way out as well being a '99.
Old Jun 7, 2020 | 09:54 PM
Michael Bazinet
6th Gear
Yup have those on the way also rebuilding the entire system while I have the manifold out new fuel lines, o rings, in tank fuel filter , regulator, new fuel pump, the whole works !
Old Jun 7, 2020 | 10:03 PM
95th 1200's Avatar
95th 1200
Fair word of warning, you will probably need to do a hot-cold idle reset on it after you're done, if you don't have a service manual it may be a good idea to get one.
