EITMS Question
Old Jun 4, 2020 | 12:21 PM
Jason S's Avatar
Jason S
I couldn't figure out how to post the actual video, but here is a link to it on YouTube:
"I turn on bike, push throttle and disable the EITMS. I turn off bike, turn it back on and push throttle and see that the EITMS is disabled. Before I turn off the bike, I push the throttle and now enable EITMS. Turn the bike off, turn it back on, and push the throttle forward. The EITMS is disabled... by logic, this means that the bike automatically defaults itself to EITMS enabled when it is shut down."
Old Jun 4, 2020 | 02:22 PM
RollaMo's Avatar
RollaMo
Originally Posted by Jason S
Mine does not work that way.
Yes, it does.
I had a 2010 Street Glide, so I know how the 2010 touring bikes worked.
Go back are read the instructions that skratch put up in post #10
Originally Posted by RyanSS
No...you're missing everyone's point. When you start the bike again, it's off (because you turned it off the last time you rode the bike). NOw....when you start the bike again and push the throttle forward until the CC light flashes....you're turning it back ON.
Try this.....turn it off.......drive the bike and verify it doesn't engage. Shut the bike off and park it. Then, when you start the bike again, just ride it. It should still be off. Everytime you're "checking" it....you're turning it back on.
Old Jun 4, 2020 | 02:32 PM
lp's Avatar
lp
You don't use the throttle to "check" to see if it's on or off. By turning the throttle, you are literally turning it on and back off again over and over.
For whatever reason this came to mind: Sorry. Just making light of it all.
Old Jun 4, 2020 | 03:44 PM
Jason S's Avatar
Jason S
Originally Posted by MyFavRk
Correct , my bike is the same way , it's always on unless you disable it every time you start your bike . The dealership can reprogram it so it stays off , and you turn it on manually , pretty much the reverse of what it is now .
I'm sticking with your response. Maybe when the apocalypse is over I will head down to the dealership and see if they can make it the way I want it to behave without charging me.
Old Jun 4, 2020 | 03:46 PM
lp's Avatar
lp
Which is incorrect for your year of bike (or any year of bike). Let us know how it goes though and good luck..
Old Jun 4, 2020 | 04:01 PM
RollaMo's Avatar
RollaMo
Yeah that's it, just ignore the advice from multiple users that know how the system works.
Old Jun 4, 2020 | 06:26 PM
MyFavRk's Avatar
MyFavRk
I'm sorry if I confused you , the dealership will end up doing the exact procedure that Skratch posted #10 , something you can do yourself . Although , it's not going to hurt to have them walk you through it ,
IBAHOG
Milwaukee Eight (M8)
14
May 15, 2017 10:59 AM
philmore81
Audio Systems
Feb 17, 2015 07:34 PM
voodoothatido4u
May 30, 2011 10:16 PM
RoadRich2010
Nov 4, 2010 10:33 AM
cubcake1
Apr 12, 2010 04:54 PM
