Automatic Chain Tensioner Noise/Wear
Note: new SE compensator was installed at 48K and new clutch at 42K.
I talked to a dealer's mechanic, because I was thinking it might be the tensioner was worn or chain stretched too much, or something along those lines also. He told me to try something before I just bought the parts and tore it down, because he thought maybe the tensioner may just not be clicking up one notch to take a little slack out. So I tried what he said and it quieted mine down.
He suggested to, when the engine was cool, find a good place to take off from a stop in 2nd gear, throttle it hard like you're on a drag strip and go up thru a few gears, then I also down shifted aggressively too lol. The idea being to load the chain so it was tight on the pulling side, thus maximizing the "slack" so to speak on the other side... and maybe the adjuster would go ahead and click a notch... and apparently it did.
Now, what I wished I had done... I wish I had gone ahead and taken it apart first, which I did anyway after I did this, just to check everything (chain slack, shoe wear, etc). If I had done that first, and had seen everything the way it was when I did open it up, I would have still tried the guys suggestion afterwards. When I did check primary the chain's tension was within spec and couldn't tighten another click, and the shoe had a little wear (similar to yours, but the grooves were about 1/2 as deep maybe). Those shoes are going to get grooves, they are wear items. Also the chain is going to "cut" or wear into the polymer shoe no matter what, as the part is a wear item. But that wear should really slow down as the chain and shoe "wear into each other".
Before you took the tensioner off, what did your chain slack measure out to? Was/is it within spec and was it towards the min or max of spec?
None of this may apply to your situation, its just what I saw in mine with something that sounded similar.
