New wheel bearings, no ABS
Old Jul 5, 2020 | 12:46 PM
Geoff1200's Avatar
Geoff1200
Default New wheel bearings, no ABS
Just replaced wheel bearings, tires & pads on my 13 FLTRU, test drive showed me no front ABS, rear is OK. There are no lights lit on the dash. I purchased AllBalls bearings for ABS , 25-1691. Any thoughts on this?
Old Jul 5, 2020 | 02:41 PM
skratch's Avatar
skratch
did you put the bearing in correctly? bunch of posts from guys putting them in the wrong side, to correct side, but upside down.
Old Jul 5, 2020 | 03:15 PM
Neggy ZRXOA 5248's Avatar
Neggy ZRXOA 5248
1) Did you put the left bearing on the left side and the right bearing on the right side ( 2 bearings per kit)
AND
2) did you put the outside face on the outside where it belongs so the sensor can pick it up
Old Jul 5, 2020 | 05:24 PM
Geoff1200's Avatar
Geoff1200
Yupp, ridge in, odd color out, left side of wheel. Sho-nough, haha
Only thing I can think of is bearing is bad, ABS encoder that is... Any way to test this?
Old Jul 5, 2020 | 07:15 PM
not a sock's Avatar
not a sock
You just did................
Old Jul 5, 2020 | 07:23 PM
caulk04's Avatar
caulk04
Magnetic viewing film.
Amazon Amazon
Would give you a good look at what's behind the curtain without trashing it.
Old Jul 5, 2020 | 09:10 PM
multihdrdr's Avatar
multihdrdr
Hmm .... that looks just like my pic that I edited with the arrows and text ...
AND
Old Jul 5, 2020 | 11:09 PM
GalvTexGuy's Avatar
GalvTexGuy
You may have damaged the wheel speed sensor.
Old Jul 6, 2020 | 09:05 AM
Geoff1200's Avatar
Geoff1200
Originally Posted by caulk04
Magnetic viewing film. https://www.amazon.com/dp/B000UV6ZPS..._-6MaFbBNW6TGJ
Genius!
Old Jul 6, 2020 | 09:43 AM
GalvTexGuy's Avatar
GalvTexGuy
So, after rereading your post, I'm not sure what you meant by "test drive showed me no front ABS." Then you say "no lights lit on the dash."
Can you elaborate on those two statements? Also, have you checked for codes? If so, what are they?
