Security code change help...
Old Jul 28, 2020 | 06:39 AM
ramu3527's Avatar
ramu3527
Makes sense...
Old Jul 28, 2020 | 07:28 AM
Oko's Avatar
Oko
Originally Posted by ramu3527
Here's a question. Why even carry the fob? It's one less thing I have to have in my pocket and I can't lose it if I don't have it.
Am I missing a reason to carry it?
Yes. Try doing the pin input after having a few (too many).
Your fellow drunks will love the curse word filled chant you will sing out.
But seriously, try the input in a pouring rain. At the end of a long day in the saddle. In the dark. Let us know how that works out.
Old Jul 28, 2020 | 07:07 PM
BigRedRK's Avatar
BigRedRK
Default from the factory is "00000". At least it was on mine.
Old Jul 28, 2020 | 08:16 PM
Bone Doc's Avatar
Bone Doc
That's impossible. The only allowable digits are 1-9.
Old Jul 28, 2020 | 09:06 PM
ratpick's Avatar
ratpick
Good way to tell if you're under .08
Old Jul 28, 2020 | 09:12 PM
Tjroadie's Avatar
Tjroadie
Usually leave factory 31313
Old Sep 15, 2020 | 09:18 AM
i4bikes's Avatar
i4bikes
1st Gear
I'm going to try this again but so far all I get to is the place where the odo is supposed to go to the code but it doesn't start blinking. Am I missing something?
Old Sep 15, 2020 | 05:20 PM
i4bikes's Avatar
i4bikes
1st Gear
Originally Posted by skratch
as per owner's manual. be aware, it can be tricky.
My bike is a 09 and the instructions have 2 different directions, 1 is step 3, this said press left turn signal 2 times, my manual says 3 times. 2nd is how you close out after you make the change. Step 15 Mine says to turn key to off before module re arms. This states turn engine stop switch to off than turn ignition off. Might be helpful to know this if you don't have a manual and are having problems.
Hawg Runner
Feb 2, 2019 04:42 PM
yzergod
Apr 7, 2013 11:07 AM
'10 Wide Glide
Mar 16, 2011 09:36 AM
rattlebones
Nov 26, 2009 10:31 AM
MAX EVO
Jun 23, 2008 05:11 AM
