2002 FLTR riser and bars
Old Jul 28, 2020 | 11:21 PM
milunchbox's Avatar
milunchbox
Default 2002 FLTR riser and bars
Im in the process of looking for new bars with risers I have stock ones now. I'm wondering how people with older Road Glides did it. Did you cut the plastics or just trim them to fit the bars. Any help is appreciated.
James
Old Jul 29, 2020 | 01:19 AM
03Machine's Avatar
03Machine
Well, I used the stock risers when I went to 12” bars But, I did consider y’all risers and decided I would trim the plastic to about 1/4” larger than bar to allow for movement even though I have poly riser bushings, there is a little movement.
Old Jul 29, 2020 | 08:58 AM
milunchbox's Avatar
milunchbox
Anyone install bars on an older model Road Glide?????
Old Jul 29, 2020 | 02:36 PM
slayrr40's Avatar
slayrr40
Default Bars
yes I have a 09 glide and installed 9” bars over the winter I added 3.5 risers putting me at about overall height 12.5 inches and did not chg any cables but did re route some of them. Also I did have to trim the plastic piece for the new risers to stick through. Use a dremmel and take your time cutting it’s not hard at all and you don’t have to remove a lot.
Old Jul 29, 2020 | 02:41 PM
slayrr40's Avatar
slayrr40
James
just go with taller bars in the first place then there will be no need to add risers or trim plastic, re use stock risers and cover. Only reason I added the risers is I should of went taller the first round and did not want to rewire new bars and purchase so I added the risers
Old Jul 29, 2020 | 07:16 PM
milunchbox's Avatar
milunchbox
I like risers so I can adjust things and change bars if I don’t like the feel.
Old Jul 30, 2020 | 09:47 AM
slayrr40's Avatar
slayrr40
Default Risers
ok cool it can be done.
Old Jul 30, 2020 | 09:58 AM
Harleylife1's Avatar
Harleylife1
James
Whenever it comes to bars i always recommend to take a look at wild 1 chubbys. Good luck n safe travels brother.
twisted-pixel
Apr 14, 2020 02:01 PM
BrandonK
Jun 12, 2019 01:33 PM
esteboatan
May 30, 2017 10:23 AM
MattCo
Aug 26, 2013 01:50 PM
crawly
Jun 1, 2010 01:05 AM
