Upgrade
Old Aug 16, 2020 | 04:21 PM
taube0dahkota@gmail.com's Avatar
Default Upgrade
I’m thinking about putting a set of 103 jugs and pistons on my 88. What will I gain with this?
Old Aug 16, 2020 | 04:30 PM
tberg725's Avatar
tberg725
With jugs and pistons you wont be able to get to 103, the biggest I know of being able to go with a TC88 is 95ci but with the kit you can up your compression, gain more HP and more TQ threw the whole RPM range
Old Aug 16, 2020 | 05:33 PM
I knew I wouldn’t get to a 103 but I was wanting more power and torque for.
Old Aug 16, 2020 | 05:41 PM
dajogejr's Avatar
dajogejr
You can take a TC88 up to 98 with jugs and pistons only from Fuel Moto.
Possibly others out there.
Lots of gain there.
Old Aug 16, 2020 | 06:06 PM
eighteight's Avatar
eighteight
Originally Posted by dajogejr
You can take a TC88 up to 98 withjugs and pistons only from Fuel Moto.
Possibly others out there..
any number of builders can bore the op s cylinders to 98” for top end only mod
Old Aug 16, 2020 | 06:14 PM
I’ve also be looking at a 107 kit with 585 cams. Opinions on this?
Old Aug 16, 2020 | 06:24 PM
Neggy ZRXOA 5248's Avatar
Neggy ZRXOA 5248
buy a complete S&S engine and get all the cubes you want.
Old Aug 16, 2020 | 06:29 PM
Screamin beagle's Avatar
Screamin beagle
Opinions on this??? Your reading comprehension sucks. Lol. Ill repeat... Unless youre going to split the cases the biggest you can go is 98 with a bore and s&s makes a 100" kit. A 98" with the right combo can be a very nice running motor. I think those 103 cylinders will yield you a huge bump up to 90" inch or so???...its all in the stroke...88"=4" stroke 96,103,110 twin cam is 4 3/8" stroke. Again if you want to go bigger than a 98 break out the checkbook
Old Aug 16, 2020 | 06:56 PM
NorthWestern's Avatar
NorthWestern
Read the replies, you cannot do this.
There is not one thing wrong with the S&S 98 incher. (if it is still available?)
My friend had one in a Softail, the high compression set up, and it was an awesome runner. This is a great solution with Andrews cams
Check with Jamie at FuelMoto, they have fantastic bolt-in big bore solutions. I love mine.
Bafflingbs
Dyno Charts
13
May 26, 2023 01:12 PM
Bluehighways
Jan 28, 2019 10:44 PM
bigpete1
Jan 9, 2017 04:23 PM
pdevore
Feb 25, 2016 03:51 PM
harley#1
Dec 18, 2015 09:23 AM
