I just installed an oil temp guage in my 04 ultra and the temp reading on it ( it's about as good as the pos air temp to read) is about 20 degrees different than the dip stick w/ temp & oil level . I installed it on the oil pan next to the drain plug using a bushing with tteflon tape on both the plug and sensor, would this cause the difference? Not a big deal but with all the knowledge on this forum, somebody might have had the same situation. Thanks in advance.
The difference is nothing to worry about. With any gauge use it as a Standard of Reference. As you ride establish what's "normal" for your bike in various conditions. Once you learn this "average" then just watch for when it changes radically and that will tell you to stop and investigate.
Out of curioustiy... What temps are the two different gauges giving you?
VDO's website says not to use Teflon tape on the threads; HD's instructions say to use Loctite 565 (IIRC) hi-temp thread sealant. The sender operates as an electrical gound sensor between the threaded part and the probe; as the temperature rises the ground increases in the sending unitcausing the gauge to rise. Theoretically, Teflon tape could interfere with the threaded grounding, but unless you really loaded the threads with tape, the tape will tear and expose the metal of the sending unitto provide an adequate ground. JMHO, of course.
Like Arizona said, I use myoil temp gaugesimply as a reference point--if I see significantly higher tempsthan normal, I'll be checking the engine; otherwise, the actual gauge reading is of no concern.
I would bet that the POS is actually the over-priced dipstick gauge!
The HD gauge (26155-07), if that's what the OP is using, has no grounding issues with the pan since it uses a separate ground wire. For it to work in the location designed, on a tee off the cooler or adapter hose (rubber) which isn't grounded, it must be designed this way. Thus, you can use sealer if you wish, although it is probably not necessary. I used the 1/8-3/8 adapter in the pan but didn't use sealant, and have no leaks.
Take the dipstick gauge and put it in a pan of boiling water. That'll tell you how accurate it is, and you can extrapolate that to the fairing-mounted gauge's reading.
I have both and used to think they were off by 20 degrees until I figured out I was reading the Harley oil temp gauge incorrectly. Look carefully for the little dots on the gauge. Note that the dot for 180 degrees is actually at the bottom end or left of the numbers 180 on the gauge.200 degrees is pretty much when the needle seems to be indicating 180. There is another dot to the right of the numbers 180 that is registering 220 degrees. Straight up is 230 degrees.
There will also be a little difference if you check the dipstick gauge as soon as you shut the bike off. Hot oil from the motor has just flowed back into the tank about where the dipstick gauge registers the temps. Wait 30 seconds to a minute and you should see the gauge agrees closer to the fairing gauge which is registering at the bottom of the oil tank.
The graduations on this gauge are not well-thought-out, and although mine may not be the same as yours I interpret them differently. I have a long line at 180 and 230°, for example, and a dot indicating the mid-points between these numerical indicators. Between the long lines are two shorter lines, and I interpret these as being 1/3's, which doesn't make sense because that calculates as 8.33°. Therefore, straight up corresponds with the long line and 230°. I think they create these markings for cosmetic appeal and not accuracy, and one can only guess what the real temperature is.
I think Iclick is right on, but sure wish the moco would have done a better job with the gauge layout. They will tell you thought that the gauge is ment as an indicator and is not meant for accuracy.
