Tire Damage Question
Old Aug 24, 2020 | 11:03 AM
RKZen's Avatar
RKZen
Originally Posted by sixgun95
How do you make sure the core is tight?
Tire valve tool. Get 'em at your auto parts store.
I had a slow leak once and put the tire under water. Just jack up the bike and dunk the lower part of the tire in a large pale of water. I found a small bubble forming on the tire about every 5 seconds.
Old Aug 24, 2020 | 11:06 AM
sixgun95's Avatar
sixgun95
Duh....what was I thinking. Yes, I did that first. If the stem is loose how do you know?
Old Aug 24, 2020 | 11:21 AM
Brewmany's Avatar
Brewmany
I would think you'd see bubbles around the base of the stem. Try wiggling it a bit.
Old Aug 24, 2020 | 11:36 AM
foxtrapper's Avatar
foxtrapper
Veteran: National Guard
Soapy water is dandy, but you don’t want it applied as a foam. That just hides what you’re trying to see. You want it “deflated”, so any bubbles or foaming is immediately visible.
Check a loose stem by moving it with that “flat” soapy water around the base. If moving the stem produces bubbles, replace the stem.
As for sitting on a flat tire damaging the tire, it shouldn’t. Let it sit that way for a year or two, cracking the sidewalk, sure, that’s damage. But just a month or so on a new tire, you should be just fine. That said, use your eyes and pay attention as you ride off.
Old Aug 29, 2020 | 06:05 PM
sixgun95's Avatar
sixgun95
Found the problem, 3 separate leaks all along the bead. Tires are right at 1 year old and have 1300 mi on Michelin Commanders. How in the hell does that happen? I would of thought from a crappy install but it literally just started. Any ideas how you would instantly get 3 leaks along the bead? Will I need a new tire?
Old Aug 29, 2020 | 06:31 PM
COOSMAN's Avatar
COOSMAN
If the tire wasn't right from the start, I'd say you'll need a new tire. I'd take it back to the shop who did the work. Their certainly has to be a warranty on the tires and with only 1300 miles on the tire, even if pro rated, you shouldn't be out much.
Old Aug 30, 2020 | 04:08 AM
eighteight's Avatar
eighteight
Valve core tool
Old Aug 30, 2020 | 04:20 AM
Andy from Sandy's Avatar
Andy from Sandy
Community Influencer
What is the condition of the rim? The fitter may not of given it a good clean and so the bead didn't seal. Might not of used plenty of lubricant to get the tyre to move on the rim. Might just be a simple job of breaking the bead and resetting it. Or more thorough by taking the tyre off and giving the rim a good clean. Check the tyre for damage.
Check the side wall of the tyre for any small cracks.
Old Aug 30, 2020 | 09:01 AM
Tjroadie's Avatar
Tjroadie
Debris can come from anywhere, could have been inside the new tire. I've seen all kinds of stuff fly when you charge the air. Just chalk it up as a life experience , nobody got hurt.
Old Aug 31, 2020 | 08:45 PM
sixgun95's Avatar
sixgun95
Evidently there was crud between the rim and tire lip from the install that gummed up and broke the seal. Fixed at the dealer for no charge. Great folks at Scottsdale HD!
0maha
EVO
21
Nov 16, 2015 05:58 AM
Iron lHorse
Oct 13, 2015 04:48 PM
SDrake65
Wheels/Tires
Jun 7, 2013 05:36 AM
jauslong
Nov 8, 2011 09:08 AM
fastnotch2002
Aug 6, 2007 02:22 PM
