Regulating The Voltage
Old Sep 14, 2020 | 06:55 PM
Ultra61's Avatar
Ultra61
Default Regulating The Voltage
Voltage gauge is jumping 13.8 to 14.3volts, bouncing high to low and far from steady voltage read cruising or increasing RPM's. Often times my radio on, has a fuzzy sound, I feel I'm leading towards this voltage movement.. I put a meter on the trickle lead and rev'd, even tho the gauge on inner fairing was traveling high to low, the meter read steady 13.83volts.
I'm leaning on voltage reg. going faulty or bad connection.. not quite sure the best way to test regulator .. If one could advise on the how too, I'm capable of doing the test
Thanks Tim
Old Sep 14, 2020 | 07:03 PM
CoolBreeze3646's Avatar
CoolBreeze3646
Thanks Tim
Here you go it is a sticky in the electrical subforum:
1 https://www.hdforums.com/forum/elect...sting-1-a.html
2 https://www.hdforums.com/forum/elect...sting-2-a.html
Usually your volt/ohm meter is not quick reacting like a voltage meter is. Check all connections to the meter and battery. How old is your battery? May be pulling more current from the voltage regulator if it is starting to go. Do the checks as above and then you should know.
Old Sep 14, 2020 | 07:05 PM
MURPHCC1's Avatar
MURPHCC1
Old Sep 14, 2020 | 07:21 PM
Ultra61's Avatar
Ultra61
Awesome links.. that should get me where I need to go
Old Mar 22, 2021 | 12:44 PM
Architect's Avatar
Architect
Old posts, great links, thanks to all that created.
SPEEDYS_HARLEY
Jun 1, 2017 04:51 AM
dochawken
Aug 2, 2015 07:33 PM
dlwilson72
Jun 15, 2012 07:31 PM
trackadaptor
Oct 16, 2011 10:24 AM
keith t
Electrical/Lighting/Alarm
Sep 28, 2011 09:01 AM
