Clunk noise from front forks
Old Sep 23, 2020 | 10:42 AM
Huff Daddy's Avatar
Huff Daddy
1st Gear
Default Clunk noise from front forks
I have a 07 Street Glide with a clunk when I ride over any not so smooth road surface (gravel, breaks in the pavement etc.) The previous owner had lowered springs installed because of a height issue and couldn't reach the ground when on the bike.
I have eliminated all other possibilities such as any loose components, bolts etc. It sounds like there's not enough oil and something is bottoming out.
Any thoughts? Thanks,
Old Sep 23, 2020 | 11:06 AM
fugawi's Avatar
fugawi
check your steering bearing. could need adjustment..
Old Sep 23, 2020 | 11:35 AM
handirifle's Avatar
handirifle
Also might take a look with the front wheel removed and see if the bolts for the damper tubes are still tight. On touring bike I believe you remove front wheel and lower axle cap. If this bolt came loose it would allow the clunk on rebound. This would be, second, after checking steering head bearings.
Old Sep 23, 2020 | 11:50 AM
Huff Daddy's Avatar
Huff Daddy
1st Gear
Thanks, I'll have a look at the steering head first.
Old Sep 23, 2020 | 11:54 AM
TriGeezer's Avatar
TriGeezer
What I’d do:
- check head bearing
- pull front wheel, and check spindle for looseness & bearings
- with wheel off, shake the forks up and down.
Old Sep 23, 2020 | 11:57 AM
Dano523's Avatar
Dano523
Don't know the miliage on the bike, but I tend to pull forks apart every 30K to rebuild them. Hence the teflon coated brass seals tend to wear out in that amount of time, and you can get the metal against metal kind of noise with shock movement as well. Plus the added slop, end up with the seals starting to fail as well.
Rebuilt kit cost about $50, new bottom and drain bolts with copper seals run about an extra $10, and two jugs of Maxima fork oil runs about $30. As for the two jugs, I pick up a jug of 15 weight from the forks, and 10w jug to do a 50/50 mix if it and the 15 weight to change the oil out in the air shocks to 12 weight at 11.5 oz per shock on there oil change.
Hence stock, the front air forks have 10 weight, the rear shocks have 7 weight oil at 11oz per shock, and just ends up with too soft/to much pogo'g of a ride. Also, with only 11oz in the rear air shock, and the OEM amount of oil in the air forks, back end does not match the front forks at half to full compression with over pogo'g to what the front is doing.
As for air pressure amount, look at the saddle back sticker for the total weight over 150lbs, and use it for the amount of air to install in the forks and shocks, to set the correct sag for the bike. On mine, it 1lb of air for every 25 lbs over 150lbs, but other bikes use slightly more air for every extra 25 lbs instead.
To sum it up, with the bike used, and knowing that someone did get into the forks to do do the spring kit, you don't have a clue of how much oil they used, nor what weight of oil as well. Also with the noise, really need to get into the forks to find the problem, and with them that far apart, may as well seal/bushing rebuild them as well.
Old Sep 23, 2020 | 12:00 PM
btsom's Avatar
btsom
If you are not getting a firm or hard shock through the handle bars, you are not bottoming the shock travel and go with the head bearings. If you are getting the hard shock through the handle bars, the forks are bottoming. Heavier shock oil may help, shimming the springs, or replacement with standard springs are about the only options. "Clunk" is normally the steering tube banging around inside the steering head tube caused by bearings being too loose..
Old Sep 23, 2020 | 04:14 PM
eighteight's Avatar
eighteight
[QUOTE=btsom;19419798], shimming the springs, QUOTE]
I would suspect the P.O. Failed to cut the spring spacers to the proper preload
lots of possibilities though
steelpony16
Aug 4, 2020 05:20 AM
orange52
2014-2024 Touring Models
Apr 12, 2014 02:17 AM
mikebaby
Aug 20, 2012 07:46 AM
jwbluebright
Aug 29, 2010 09:32 PM
Birdman143
May 28, 2008 03:57 PM
