Starter Removal nightmare
Old Oct 12, 2020 | 06:26 PM
lunyty1's Avatar
lunyty1
Default Starter Removal nightmare
2004 ultra,was going to change the starter clutch and cannot get the starter out......i took off the chrome end cover but the starter keeps hitting the oil tank fill hole,,,do i need to clock this thing or what ?? had to walk away before the bullets flew....any help appreciated...done many starters over the years,Pan ,Shovel ,Evo never had trouble like this
Old Oct 13, 2020 | 06:27 AM
foxtrapper's Avatar
foxtrapper
Veteran: National Guard
There was fiddling involved with getting it in and out of my 04. Both some rotation and angling.
Disconnecting the wires from the starter, and some others in the area greatly helped.
Old Oct 13, 2020 | 07:32 AM
Dano523's Avatar
Dano523
Check your manual, but on the older bikes, you have to unbolt the starter bendex gear nose section from the primary side of the starter to remove the front end parts out that primary side (drain primary and remove primary cover to get to the bolt), then the rest of the starter (motor) will slip out the back side of the primary cover.
Old Oct 13, 2020 | 09:07 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
This method applies to all 5 speed Big Twins.
Alan7407
13
Mar 18, 2026 07:12 PM
Chummers
General Topics/Tech Tips
Aug 26, 2013 12:06 PM
Boat drinks
Feb 1, 2013 09:06 AM
WeeblesWobbles
Sep 26, 2007 03:11 PM
02glide
Nov 18, 2006 06:05 PM
