Revo A, different than normal questions
Motorcycle: 2017 Ultra Limited
Current mileage: 51,xxx
Legend Revo A's installed by me 01/01/2020 @ 37,795mi
Everything was great for awhile; wife loved them (she is the only reason I bought them). But over the course of the year they gradually lost their charm although I had never readjusted the settings (I set the sag for 2 and left it there). Then they started bottoming out. I swapped back to the factory shocks just to ensure it wasn't an issue caused by something else; the problem went away. I put about 2,000mi on trying different settings; going both directions and and even large adjustments just to see what they'd do and even swapping back & forth with factory shocks a time or two. I had been in contact with Legend Support (Chase was super) the whole way and finally sent them back for repair. They got them, repaired and sent back out the same day even. But I have no explanation as to what was wrong; what they did. The only problem with that is that I wanted to be sure I hadn't been doing something wrong or missing something simple and the case was immediately closed so that I couldn't comment anymore to ask. SO....
I went to install them but I am having a problem getting sag and having the left and right even. I turned them even number of turns at the first but then the left had more sag even though they were equal length. It will not correct. The bike is in a chock, upright. My wife was measuring while I sat (yes she's capable lol). There's about a 3/8" difference in threads right now with the same sag. When I put them on last night, I did them one at a time with the bike supported completely on my lift so there was full extension. I saw one little statement from someone in all the videos & forum comments I've seen that stated to start with no shocks on. I can't really see where that would make a difference with it being up in the air and free but...I've got nothing so far. Problems with the swing arm? Possible I guess but highly unlikely in my mind; tire wear is fine, smooth ride, no pulling of any kind, etc. I think this difference was happening before I sent them back but I was trying so many different things that I can't say for sure now.
Anyway, if someone has an idea to try, thank you.
Also, the large aluminum spacers that go between the shocks and the bike, are they designed to conform to the shock & bike as you tighten the bolts? Harley manual specifies a heavy torque value (746' lb is the light end). I used that low end of the torque range but I can tell the spacers are squished a bit but the shocks still swivel on the bearings just fine. Aluminum is soft so I'm thinking/hoping that's by design? I got new spacers from Legend; the previous spacers had done the same thing.
Thanks again. It's late on a Friday night; going into the weekend some places ain't open but I'm hoping to ride a little tomorrow.
I think your torque spec is a bit off....
So I'm extremely curious if the spacers are supposed to squish. 746 ft lbs is a lot.
I don't know that I would be all that concerned about the shocks not being precisely the same. I will admit in not totally familiar with them though.
If no, then swing arm is not true to the frame, and time to start checking adjustment parts for wear, then re-true the swing arm/motor to the frame.
Also, don't remember what year HD went to the fixed length top link on the motor, but would replace that with a adjustable link to to correct cant of the motor/swing arm as well.
Simply put, if you are having different length of the shocks from top to bottom bolts against each side, its not the shocks, but swing arm/motor that is not aligned correctly to the frame isntead.
Thanks for your input guys. Ill keep checking back for more feedback.
Left - 13.5
Right - 13.25
I dont know how significant that is but someone else may. Ill keep looking at other things.
Dano523 I am thinking about your reply and my question is, when you talk about the bolt hole distances, is there a tolerance range that you are familiar with? Thats why Im not sure if that 1/4 difference is an issue or not. Im thinking it probably is, but I have no specific guidelines yet.
Left - 13.5
Right - 13.25
Because the torque wrench I used was in inches. All ya gotta do is multiply or divide by 12, whichever way you want to go. No big deal; same torque.
