Have had a few Honda's in the past in fact still have a VT1100 Shadow for anyone that wants to ride and didn't bring a putt.... Your son's bike shound like a bent shifter fork.... Only fix is to open the tranny up and replace it...
Check the star wheel behind clutch? That is where you would want to start. you will see a roller on a spring loaded lever. It fits into the star wheel holds the gear. See if the star wheel in loose? back out screw , clean use lock tight (blue). tighten. If this is not the problem?
1. worn shift fork bolt -follows shift cam groves.
2. shift fork worn.
3. worn shift cam. Thats the part the shift forks are attached to..
4. dogs on gears. easy to spot. they will be round of.
5. e-clip broken in/on counter shaft. gear sliding on shaft.Only found this 1 about a dozen times. mostly bike that were raced.
remove side cover for star wheel.
remove engine and split cases for the rest.
I live in Easton,Pa.worked on motorcycles for 37 years.
Guys I sure thank you for all the help, I'll try the easy stufffirst and if that dosent fix the problem I'll probably just help him part it out on ebay
