Accessory Jack?
Old Jul 30, 2007 | 04:59 PM
tmoreau's Avatar
tmoreau
Default Accessory Jack?
We have an 07 Ultra. There is an accessory switch on the handlebar panel that says ACC. The owner's manual says that there is a connector next to the battery where you can hook into accessory power. When I pulled the saddle and looked. It wasn't there. Anyone care to give me a clue?
TIA
Old Jul 30, 2007 | 05:20 PM
gman's Avatar
gman
Default RE: Accessory Jack?
mine was right in front of the battery. it was a couple of wires with a connector and plug on it. just look for a wire with a cap on it. i have my Road Zeppelin plugged into it, but it also will support heated clothing, etc.
Old Jul 30, 2007 | 06:04 PM
electra trike's Avatar
electra trike
The ACC plug is grey in color. Keep looking.
Old Jul 30, 2007 | 06:43 PM
stro1965's Avatar
stro1965
It's there Tmoreau, I had to look for mine too. Look right at the rear of the tank in the void.
Old Jul 31, 2007 | 06:04 AM
tmoreau's Avatar
tmoreau
Thax. Next time I have the saddle off, I'll dive down there for a second look.
Old Jul 31, 2007 | 06:55 AM
NCCopBikeRider's Avatar
NCCopBikeRider
On the Cop Glide, we had to remove the battery to get to the connector. As stated above, it is a square grey plug with a cap the must be removed before use.
Ride Em Carry em
Old Jul 31, 2007 | 10:56 AM
dstockton's Avatar
dstockton
ORIGINAL: tmoreau
Be careful you get the right grey plug. There is an identical grey connector under the right side panel that's for the dealer diagnostic computer plug in. Don't ask me how I know it's identical to the acc plug. It won't hurt you plugging an acc item in it, you just won't get any power to it. My true acc grey plug was really buried in front of the battery.
Old Jul 31, 2007 | 01:01 PM
NCCopBikeRider
The Real ACC plug will hae a cap that needs to be removed prior to connecting the new harness.
Ride Em Carry EM
Old Jul 31, 2007 | 04:59 PM
tmoreau's Avatar
tmoreau
Hmm. When I initially went to look for that plug back in June, I noticed that the battery was in there so tight I couldn't remove it. I winder if what's holding it back is the fact that the acc plug is wedged in there. Oh well, I'll have to find out when I pull the saddle.
Old Aug 3, 2007 | 01:49 PM
tmoreau's Avatar
tmoreau
I may have found it, but it wasn't too obvious - at least to me. I'm attaching a photo. The thing is bent down and tie-wrapped. I didn't want to snip the tie-wrap until hearing back from this forum.
[IMG]local://upfiles/36164/F437C236004E4CACBE666855A66BF4B5.jpg[/IMG]
wombat457
Aug 14, 2015 03:43 PM
Mr. Clean
May 17, 2013 11:40 AM
DrPlastic
Sep 17, 2010 02:31 AM
rcdifalco
May 28, 2010 09:14 PM
msbhvn
Apr 16, 2006 02:06 PM
