Passing lights installation
Old Jan 20, 2021 | 10:07 PM
FIL_05's Avatar
FIL_05
Default Passing lights installation
I’m trying to install these OEM halogen passing lights on my 99 EG. i connect the ground with ground and the other wire with the white wire you see in the pics but lights won’t turn on.. can someone help to understand why?
They come from a 99 RK and they worked no problem.. don’t know if the owner did and mod..
next step will be to install halogen headlamp, will it require any mod?
Old Jan 21, 2021 | 05:35 AM
eighteight's Avatar
eighteight
Do you have headlamp switch on "Lo" beam ?
Old Jan 21, 2021 | 08:10 AM
FIL_05's Avatar
FIL_05
Of course... and when i put back its stock passing lights they work..
so it’s something related to the halogen lights..
Old Jan 21, 2021 | 12:38 PM
bobter3's Avatar
bobter3
Have you tried switching the wires? Do the new ones work bench testing them?
Old Jan 26, 2021 | 10:48 PM
FIL_05's Avatar
FIL_05
does anybody know if that white wire is the electricity or the ground?
Old Jan 27, 2021 | 04:23 AM
kojak's Avatar
kojak
ground is usually black.
Old Jan 27, 2021 | 06:41 AM
MCSarge's Avatar
MCSarge
Stick a 9 volt battery on the end of the terminals and note which way it lights up then wire it accordingly. I do that a lot as some Chinese company's have been known to use the black wire as the power wire especially on LED Lights.
Old Jan 27, 2021 | 10:32 AM
Bingee's Avatar
Bingee
I believe those lights are a kit part # 68208-98A. Here are the instructions.
File Type: pdf
Storm1972
Electrical/Lighting/Alarm
18
Jan 14, 2019 09:37 AM
Stingray702
Jul 18, 2018 08:08 AM
Genetic Beast Lobster
Dec 5, 2013 09:50 AM
JAWS49
Nov 8, 2012 12:51 PM
jerseyjeff62
Aug 17, 2011 01:09 PM
