Saddle Bag Tether Strap Repair ????
Old Feb 9, 2021 | 08:02 PM
WVHARLEEMANN's Avatar
WVHARLEEMANN
Default Saddle Bag Tether Strap Repair ????
Hey forum touring experts. The title says it all here. I have a 2005 Electra Glide with the factory hard bags. This afternoon while getting out my air shock pump the tether strap posts broke from the top on my left side bag. This looks like 2 plastic like legs (2-3 inches long) guessing here that were mounted/moulded into the top inside lid. Broke perfectly flush. What is the best route for this repair? To run a bit longer screws back into the area, I'm afraid of going through the lid. Glue them back ??? Afraid they would not hold up. HELP !!!! Thanks all for your ideas here. You guys are great !!!!!!
Old Feb 9, 2021 | 08:33 PM
Taggs's Avatar
Taggs
Any chance you could provide a pic?
Old Feb 9, 2021 | 08:59 PM
WVHARLEEMANN
Hello. Yes Sir. Let me go and take a few for you. Appreciate you taking a look. Give me 5 or so minutes.
Old Feb 9, 2021 | 09:12 PM
WVHARLEEMANN
Here are a few pictures of my issue. Old guy here and my picture taking pictures are not the greatest. LOL. Thanks again.
Attached Thumbnails Saddle Bag Tether Strap Repair ????-img_5663.jpg   Saddle Bag Tether Strap Repair ????-img_5664.jpg   Saddle Bag Tether Strap Repair ????-img_5665.jpg   Saddle Bag Tether Strap Repair ????-img_5667.jpg
Old Feb 9, 2021 | 10:25 PM
cncmike's Avatar
cncmike
I am pretty sure that the bags are ABS plastic. If so ABS pipe cement from the hardware store will be the best glue for it. That type of glue actualy melts the plastic to make both parts melt into each other. The same way PVC works on plastic pipe just a different plastic.
Old Feb 9, 2021 | 10:37 PM
WVHARLEEMANN
Thanks. I actually never thought of that. Appreciate the follow up.
Old Feb 9, 2021 | 11:47 PM
Taggs's Avatar
Taggs
I d go with the pvc cement attempt as well. Try the cvpvc cement , orange. It’s a one step application. Much better than the two step primer then cement type. Usually will grab hold in about 15 to 20 seconds if it’s going to bite on at all. Make sure the surfaces are clean as possible. From your pics it appears there’s a glue residue. I think I’d try to remove that leaving clean smooth surfaces.
Old Feb 10, 2021 | 04:56 AM
WVHARLEEMANN
Smile
Well thanks very much here for your insight. That's 2 thumbs up for the cement process. I will get the orange and give it a try after a good cleaning. If it sets properly and feels strong a little black paint touch up with a artists brush and I'm back in business. THANKS !!!!
Old Feb 10, 2021 | 05:07 AM
WVHARLEEMANN
Wonder if this GORILLA CEMENT would even be better. I have had very good luck with there products. But then again, Oatey has been around forever. Probably a toss up.
Gorilla PVC Cement Gold Gold, 16 OZ, CPVC Glue, 1 Step Solvent 16303
1 Step Solvent Cement Designed Specifically For Use In Joining All Types Of CPVC Pipe & Fittings With Interference Fit Thru 2" Diameter, Including Flow -Guard Gold CPVC, Fast Setting, High Strength CPVC Cement, 1148 Can Be Used Without Primer Where Local Codes Permit, 1148 Meets Low VOC Requirements, Outlined By SACQMD 1168/316A.
Oatey CPVC Medium Bodied Fast Set Orange Cement is recommended for residential and commercial hot and cold water systems. It is approved for Corzan CPVC Piping Systems. Oatey products have earned the trust of plumbing professionals for over 100 years.
Recommended for residential and commercial hot and cold water systems up to 200°F / 93°C
For use on all schedules and classes of CPVC pipe and fittings up to 6 in. diameter with interference fit
Approved for CorzanŽ CPVC Piping Systems, Corzan is a registered trademark of The Lubrizol Corporation
Recommended application temperature 40°F to 110°F / 4°C to 43°C
All Oatey solvent cement and primer products are certified to UL Greenguard Gold
Lo VOC Solvent Cement that meets California South Coast Air Quality Management Districts (SCAQMD) 1168/316A or BAAQMD Method 40 requirements
Meets ASTM Standard F493
Old Feb 10, 2021 | 06:28 AM
foxtrapper's Avatar
foxtrapper
Veteran: National Guard
Far as I know, pvc cement/glue will not work on abs plastic.
