Went in for cam pads replaces,and found this...
Old Feb 23, 2021 | 12:37 PM
vdude's Avatar
vdude
Default Went in for cam pads replaces,and found this...
Went in to get an upgrade for my cam chain pads, and found out one of the cams was shot.
The bearing were fine, but the cam was worn. Kind of odd 2004 roadking with 22,000 on it. lot of shaving too.
i guess its always good to check..
Old Feb 23, 2021 | 12:52 PM
svarnster's Avatar
svarnster
post some pictures if possible. Glad u caught it.
Old Feb 23, 2021 | 12:55 PM
TriGeezer's Avatar
TriGeezer
Assuming it was an OEM cam? Make sure you replace the lifters too. Something was not right to cause the cam to wear.
Also, I’m curious, if they were just replacing the adjuster pads, why’d they pull the cams?
Old Feb 23, 2021 | 01:11 PM
cwsharp's Avatar
cwsharp
My inner cam journals were shot at 30k on my '06 Nightrain. That was caused by the really lousy cam bearings that were made in Asia and were stock from HD. Replaced them with Torrington brgs and never looked back... and got to up the performance from the cams and change to a piggy back ECM. Woke the bike up that's for sure.
Old Feb 23, 2021 | 01:52 PM
MACDBF's Avatar
MACDBF
Glad you caught it early, might as well get the bearings changed out since they already have it opened up.
Mac
Old Feb 23, 2021 | 01:59 PM
Campy Roadie's Avatar
Campy Roadie
Maybe I misunderstood your question, but the cam plate and cams have to pulled from the cam chest to get a direct view of the rear tensioner pad or to replace it.
Old Feb 25, 2021 | 11:36 AM
vdude's Avatar
vdude
It was my inner cam journal on one cam .
I changed the cams, lifters, cam plate, bearing, oil pump and adjusters. Also needed to flush all the steel shaving out of the motor.
I glad we found it, because the pads looked ok, but i decide to change them anyway. You just get lucky sometimes...
Old Feb 25, 2021 | 07:39 PM
Tcrafty's Avatar
Tcrafty
A good friend calls that a, (Significant Opportunity for Improvement) SOI....
Time for a cam upgrade and some bearins'!
Dynawide1976
Dec 1, 2020 09:41 PM
LQQK_OUT
Engine Mechanical Topics
Sep 24, 2018 09:44 AM
Shadowfax
22
Dec 26, 2016 08:46 AM
archergodwin
Apr 25, 2016 09:15 AM
LunaticFringe
Dec 25, 2015 08:01 AM
