Cruise control question 2007 Ultra
Old Mar 6, 2021 | 11:06 AM
UNIT979's Avatar
UNIT979
Default Cruise control question 2007 Ultra
Last year I was experiencing all around electrical problems. 1st dealer replaced everything electrical and couldn't fix the problem. Ended up being a wire periodically shorting out.
Anyways, around the same time (coincidence?), my cruise control "set" switch would short out my rear lights (brake /signals), blowing the 15am fuse, and of course the cruise would not work.
I got my bike back at the end of the year and didn't try the cruise because they said they just fixed the wire shorting problem at the time.
NOW, when I push the "set" for cruise, nothing happens, however the fuse does not blow and lights stay on.
Anyone ever experience this. Not looking for answers that just say "its your switch/bad module/wiring", unless you have experienced this issue. I am aware it is one of the 3, lol!
Thanks,
Brad
Old Mar 7, 2021 | 10:26 AM
EdwardK's Avatar
EdwardK
I haven't experienced your issue with bad wiring but I have had my rear brake switch fail twice on my 08 that will not let the cruise set. You obviously know what the issues could be so your just going to need to start trouble shooting. Start with simplest first, the brake lights. Are they on all the time? Brake light switches usually fail on and will not let the cruise set. Turn the ignition on, don't have to start it and hit the brakes, does the brake light come on? Move on from there troubleshooting.
Good luck!
Old Mar 7, 2021 | 02:01 PM
hdbob2006's Avatar
hdbob2006
2nd switch to check is the rool-back switch on the idle cable.I've heard of those going bad often.
UNIT979
Electrical/Lighting/Alarm
29
Mar 7, 2021 11:23 PM
imbuhlman
Jul 10, 2020 06:40 AM
johnod
EVO
Jul 27, 2017 01:47 PM
SMenasco
Aug 19, 2006 10:28 PM
ebaswell
Apr 28, 2005 03:56 PM
