Ok my first question here boys and I'm a bit confused about this thing, o ride down to Jax today all on interstate and I only got 98 miles on a full tank. The light was on, I was well into the red but when I stopped i only got 3.2 gallons. I've filled up twice today with the same results, 98 to 106 miles to a tank but only took 3.2 to 3.3 gallons to fill up. Is this normal? I've only had this thing a week. Btw it is injected and dead stock
30 ish MPG was normal for my '00 Electra with the TC88, which is about what you're getting. And worse with a headwind. Don't trust the gas gauge, they didn't work very well back then.
welcome to the forum. and congrats on the new ride. Bone stock running 70 that seems a little low. running 90 that is not too far off. I would open her up with a set of pipes and an air cleaner. Probably get better mileage. I average in the 40's
I have a 2000 Ultra Classic, TC88 bumped to 100 inches with cams, Thunderheader, etc on bad days I get 30 mpg. On good days 35 - 40 (difference being city or combined vs highway cruise). Mileage prior to the mods was typically 35 ish.
The Magneti Marelli fuel injection system on your bike and mine is crap and old as the hills. I'll be dumping mine soon and switching to a carburetor because switching to a later generation fuel injection is just too much money and work for a 20 year old bike.
Bottom line is your mileage isn't horrible for your bike, but it's not great either.
I realize now that your question is probably more about the size of your fuel tank and why you're only getting 3.2 to 3.3 gallons into it when the low fuel light comes on. As someone else says, these fuel gauges on these bikes get pretty wonky over time and I definitely don't rely on mine.
If you know you're getting 30 miles per gallon and you got a 5 gallon tank, just reset your trip meter at every fill up and stop for gas every n number of miles or so (140 maybe?) But do still be aware of how your fuel gauge is reading because if you're riding against a headwind or at erratic speeds you could be getting less than 30 and taking it to 150 could leave you stranded on the side of the road.
While you're learning the reality of your bikes fuel consumption, as you start getting into the higher miles per tank full you can occasionally pull over and glance down inside of your tank to see how the fuel level looks.
Wondering, do you have a split tank? Meaning two fuel fill caps? If so you may be only filling one side,
The left tank cap has reverse threads, and there is a crossover hose in front .
What Z said, pay little attention to the needle and reset the trip gauge at every fuel stop.
Booker, unless it's a custom build the left side is just a gauge, doesn't have a filler hole.
