Ignition on wire question
Old Apr 9, 2021 | 03:00 PM
eddie31770's Avatar
eddie31770
Default Ignition on wire question
I am thinking of one of those Kuryakyn sound bars for my 2018 Road King (no opinions on the sound please). I also don't necessarily want to get a harley wiring harness add on update/upgrade. So the question is, on a 2018 RK where is the best place to tap a wire for ignition on for this speaker? Any help woudl be greatly apprciated.
Old Apr 9, 2021 | 06:18 PM
MyFavRk's Avatar
MyFavRk
Not 100 % sure , but you should have a power source in your headlight , two open leads you can use to power it . Hopefully another member will chime in and verify that .
Old Apr 9, 2021 | 06:49 PM
eddie31770's Avatar
eddie31770
Thank you for the response. I'm trying to avoid taking the headlight apart. Hoping there is a wire to tap under the seat where I'll run the wires from the speaker.
Old Apr 9, 2021 | 07:17 PM
MyFavRk's Avatar
MyFavRk
You should have two leads under the seat as well for a heated seat etc , if you don't have a wiring diagram , there is a hd web site you can go to and see it there , never been there myself , so maybe someone will post a link .
Old Apr 9, 2021 | 07:29 PM
GalvTexGuy's Avatar
GalvTexGuy
https://serviceinfo.harley-davidson....view?id=239371
Old Apr 10, 2021 | 10:19 AM
eddie31770's Avatar
eddie31770
Thank you. Unfortunately, to me, reading this diagram is like reading a foreign language.
If anyone has a picture or good description of where and what the wire looks like I would greatly appreciate it
Old Apr 10, 2021 | 04:46 PM
GalvTexGuy's Avatar
GalvTexGuy
I looked at the wiring diagram I linked to, but the diagrams for Touring Models only shows for fairing and non-faring bikes and, at best, which diagram goes to a 2018 Road King is still confusing.
Look under the seat for a V/BE (violet/blue) wire. I believe that is P&A accessory switched power wire. If you have a 12VDC test light, test the wire to be sure it is only powered when the ignition switch is "on". If it is, use the provided t-tap on the wire and connect the orange wire from the sound bar to it.
Of course, the red (fused) wire and the black wire go to the battery.
Old Apr 10, 2021 | 06:40 PM
eddie31770's Avatar
eddie31770
Thank you. That's what I was looking for the violet/blue wire is the one.
Old Apr 10, 2021 | 08:10 PM
GalvTexGuy's Avatar
GalvTexGuy
Glad you found it. 👍🏼
AngryAmish1163
Jul 27, 2017 05:20 PM
sgr60
EVO
20
Mar 1, 2017 05:33 PM
joker77535
Jul 5, 2013 11:27 AM
jacknthebox
Apr 22, 2013 09:03 AM
woodworking1
Aug 5, 2010 01:54 AM
