Dimming Headlight?
Old Apr 14, 2021 | 09:29 AM
Vahomboy's Avatar
Vahomboy
Default Dimming Headlight?
2018 Ultra Limited, stock LED headlight. My riding buddies say when they looked in the mirror Sunday they said they could barely see my headlight - looked dim. Said the two side lights looked brighter than the headlight. Being a rider, hadn't noticed, I very seldom ride after dark to really use it. My bud is a regular visitor at the local HD dealership and told the service manager about it. I carried it by there yesterday and the service manager compared it side by side to another bike, same light, and said it looked good but seems to be pointing downward - thus needing adjustment. He adjusted both, headlight and side lights. He also said he hasn't heard anything in a while of issues with these lights. Have you guys heard or had any issues with these lights? Thanks.
Old Apr 14, 2021 | 10:18 AM
jimglassford's Avatar
jimglassford
Wouldn't it be best to just turn on the headlight in your garage to see how bright it is or one night, just park the motorcycle in front of the garage door and turn on the lights?
Old Apr 14, 2021 | 02:01 PM
caulk04's Avatar
caulk04
Likely they were just below the cutoff which would make it appear much less bright. If it was aimed down like service said, that would exacerbate the effect.
Old Apr 15, 2021 | 07:43 AM
Vahomboy's Avatar
Vahomboy
I haven't had time to night check it but in the garage I'm not sure. Not something I paid a lot of attention to. Now I'm afraid if I do it this way. I can almost make myself see it any way I want it to appear.
Old Apr 15, 2021 | 08:03 AM
kloccwork419's Avatar
kloccwork419
Sounds like it might need adjusted. Maybe its pointing too far down or up in the trees
Probably just vibrated loose. Its pretty simple to do yourself if it happens again. OR maybe your spotlights are just brighter bulbs. My riding buddies think one of my bulbs went out in my center taillight, compared the the running signal lights, but theres only one bulb in it. 😂.
Heres what my service manual says if you want to check it out. Yours is newer but Im sure around the same measurements for adjustment.
Old Apr 15, 2021 | 08:25 AM
eighteight's Avatar
eighteight
Post # 1 the lights were re- aimed at the dealer.
Old Apr 15, 2021 | 09:55 AM
kloccwork419
Because everything done at a dealer is done correct and to perfection. I forgot. My bad
Old Apr 15, 2021 | 10:06 AM
eighteight's Avatar
eighteight
Was not inferring that at all , sorry.
City Worker
Mar 20, 2018 05:32 AM
twosailin
2014-2024 Touring Models
Sep 23, 2015 12:11 PM
goats
May 11, 2012 05:11 PM
tx-skydiver
Dec 22, 2011 08:47 AM
SecondChance!!
Panhead
Apr 20, 2011 08:55 AM
