Street glide code
Old Apr 27, 2021 | 07:02 PM
Michael Sprunger's Avatar
Michael Sprunger
Stage III
Default Street glide code
I have a 2017 street glide special. Has a 465 cam, Arlen ness intake, Vance and Hines x-pipe and a power commander. Bike continues to throw code p1032 and p1052 which are running rich front and back. My mechanic (40 yrs plus) is having a hard time figuring it out. Has dyno’d several times, set and reset the map and still kicks codes. Mostly when the engine is cold. Anyone have any ideas? Thank you!
Old Apr 27, 2021 | 08:30 PM
702's Avatar
702
You might get answers in the tuning section - https://www.hdforums.com/forum/ignit...-injection-55/
Old Apr 27, 2021 | 09:48 PM
Dseago1969's Avatar
Dseago1969
When were the upgrades done on the bike? How long after did the dtc’s show up? Were they ever cleared or maybe history (they will stay on for about 30-50 rides without manually clearing).
Depending on your answers I’d start checking connections. F that, I’m checking them anyway, doesn’t hurt to rule it all out. I’d also start with O2 sensors.
Motorcycles sure have changed in 40 years. Maybe your mechanic has a friend that can offer up fresh ideas.
Old May 30, 2021 | 07:46 AM
Michael Sprunger
Stage III
The upgrades were done last fall. Started with a Vance and Hines tuner, it totally screwed up everything. Did not work properly, ran so rich that I smelled like gas after each ride and Vance and Hines remapped it 8 times and never got it right. Put a power commander on it and put on dyno to tune. Code has been on ever since. Changed O2 sensors and still comes on. Took to Harley and they reset the ecm to stick settings didn’t help.
Old May 30, 2021 | 08:23 AM
Dseago1969's Avatar
Dseago1969
First, just checking codes are they p0132 and p0152 so 1 and 0 just misplaced?
A few things can cause this. I would check all of the wiring for the O2 sensors from the exhaust to the ECM and make sure they are plugged in correctly and not mixed up. Check header bolts. Check head temp sensors. Stuck open injectors could be a problem.
Check and recheck everything that was done. O2 sensors, black is back when you check to make sure they are connected correctly.
Old May 19, 2024 | 08:49 PM
Tony Ry's Avatar
Tony Ry
Stage II
Default Any luck?
Just wondering if there was any resolution to this? I’m having the exact same issue in my 19’ S/G special after the 465 cam install. Using the dynotuner. Bike runs phenomenal but I get these codes after 2-3 key cycles.
Old May 20, 2024 | 04:20 PM
big-C's Avatar
big-C
The OP hasn't been active on the site since 5/2021.
Old May 20, 2024 | 04:31 PM
Tony Ry's Avatar
Tony Ry
Stage II
Yea I see that, when you’re struggling for answers, it was worth a shot.
Camoprice99
Mar 9, 2021 08:29 PM
TravelingTall
Harley Davidson Videos
Jun 14, 2019 06:32 AM
Reno36
General Topics/Tech Tips
Aug 6, 2018 12:09 AM
chicanagirl
Aug 19, 2017 01:23 PM
Picit
Powdercoat & Paint
Jun 22, 2016 07:27 AM
