Won’t start in gear?
Old May 17, 2021 | 07:57 PM
leftyjm's Avatar
leftyjm
I just last week had to have my LH switch pack changed. Not starting in gear is the prime issue. Mine also would shut down completely coming to a stop, no power, no lights no anything, then after a few minutes it would start. Lastly the gear indicator would jump around from showing 3rd, to first to 2nd, crazy ****.
If you can find that switch pack have it changed. It was about $225 and my dealer only charged me a half hour installation.
They are hard to find so I wouldn’t delay in locating one.
Good luck
Old May 17, 2021 | 09:55 PM
booze hound's Avatar
booze hound
Originally Posted by Andy from Sandy
If the bike starts in neutral then that would eliminate the neutral switch.
It points to the clutch switch but unfortunately on a CAN bus bike it is not a switch per se but a device that sends a command to the BCM to be interpreted.
Do all the other switches on the right hand side work? Do you have any error codes?
I believe the all of the switches do work but I’ll double check tomorrow. Have not pulled codes yet but have a look at that as well.
I found some info from Fuel Moto that explains how to get the codes as well as what each one means so maybe I’ll get a clue there.
Old May 17, 2021 | 09:58 PM
booze hound
Originally Posted by Kawickrice
Clutch switch pak has a mini circuit board that goes out occasionally without being hit. I would check there first
Thanks....I’m thinking the same thing. How can I test the circuit board?
Still seems so coincidental....was working fine before I got hit.
Old May 17, 2021 | 10:02 PM
booze hound
Originally Posted by Simpleman71
If the neutral safety switch is bad the bike will only start in neutral and not in gear. My 18 street glide did this on my way to Daytona this year. Still haven't swapped it out, bike won't start in gear but does in neutral. My cruise also works. Dealer told me this issue is very common.
‘Thanks Simpleman.
I’ll definitely check that out.
Old May 17, 2021 | 10:06 PM
booze hound
Originally Posted by roussfam
I'm guessing she was a cutie? Lol
‘If she was a cutie I probably wouldn’t have been so pissed. This lady had about a 2 year old kid wandering around and definitely wasn’t cute!
Old May 18, 2021 | 02:18 AM
Andy from Sandy's Avatar
Andy from Sandy
Community Influencer
If it is bad such that you don't get the lamp on the dash the BCM will think the bike is in gear and ought to then only start if you pull in the clutch.
Can you start your bike with it in neutral? I don't think you have actually said or not.
Old May 18, 2021 | 08:42 AM
Freakin Deacon's Avatar
Freakin Deacon
A timely thread for me!
Purchased a 2016 CVO Limited in January, I'm still getting to know it.
It wont start in Neutral
Glad to find out it is somewhat common
is the safety Interlock the same as the Neutral safety switch?
Thanks to all!
Old May 18, 2021 | 11:24 AM
KCFLHRC's Avatar
KCFLHRC
If you got hit in the rear start looking there. Make sure the brake light is working properly.
Old May 18, 2021 | 11:21 PM
Simpleman71's Avatar
Simpleman71
My bike won't start in gear with clutch pulled. If I put it in neutral it will start whether the clutch is pulled or not. Hope this helps
Old May 19, 2021 | 02:26 AM
Andy from Sandy
This tells me the clutch switch is faulty in some way.
Above others have already mentioned trouble with the module in the hand controls.
I wouldn't just guess at this point but get a dealer to diagnose. Hopefully they only charge for the part that actually fixes the fault and not other parts they might have used along the way.
