Big bore
Old May 30, 2021 | 10:04 PM
Hammz's Avatar
Hammz
Originally Posted by jdcinak
Thanks for the info guys. Can anyone recommend a cam for this build?
Maybe you should decide on what displacement first?
Old May 30, 2021 | 11:35 PM
jdcinak's Avatar
jdcinak
I’m going with the 103
Old Jun 1, 2021 | 10:28 AM
Hammz's Avatar
Hammz
OK. Your money, your bike. Going to be an expensive build when you change crank/flywheels.
I would have just built a 95" if it were me, using the 103" cylinders & SE heads, with the stock cases/crank/flywheels.
I'd send the cases to Dark Horse & let them do their magic to make things a solid build, including upgrading the left crank Timken bearing setup. The new crank from them is $1600 plus new rods, another $300 to $900. You'll want it balanced, so add another $525 for that. The cases work will be another $900 to $1400 to update to 07 & later cam conversion and Timken bearing. You could easily put $6,000 into that 103" upgrade before adding cams, lifters, oil pump & pushrods, which could be another $2,000. Plus labor (from your questions, it seems clear you don't have the knowledge to do the work yourself) so add 10 plus hours at maybe $150/hour?
For less than $4600 you can purchase a new 103" H-D long Block with matching VIN number. Yea, it won't be a Dark Horse solid build, but it will include the upgraded left crank bearing & much more. And it will still need a cam & tune upgrade.
Old Jun 1, 2021 | 11:18 AM
jdcinak's Avatar
jdcinak
ok then, that sounds a bit rich for my blood so, if I use my 103 heads and cylinders I’ll just have to get new pistons for the stock wheels correct?
Old Jun 1, 2021 | 02:14 PM
roussfam's Avatar
roussfam
Yes that's right. Let the guys know what cams you are considering and they can suggest a suitable piston. Different pistons, even though they are all 95", can give you different compression ratios which can make a big difference depending on what cam you use.
Jim
Old Jun 1, 2021 | 03:42 PM
Hammz's Avatar
Hammz
Almost. You'll need cams & various valve train components. Then you'll need a tuner & tune to make it all work. Much less money & will still provide a decent performance update as a 95 inch motor.
Old Jun 1, 2021 | 03:49 PM
jdcinak's Avatar
jdcinak
Does anyone have a build list for something like this? Surely someone else has done this build before.
Old Jun 1, 2021 | 04:01 PM
Hammz's Avatar
Hammz
Maybe something like this?
Old Jun 1, 2021 | 05:42 PM
jdcinak's Avatar
jdcinak
sorta, I was thinking more along the lines of part numbers
Old Jun 1, 2021 | 06:21 PM
roussfam's Avatar
roussfam
Sell your 103 Jugs and Pistons, but keep your heads. Call Fuel Moto, get a price on a 98" kit. It will have everything you need, jugs, pistons, cams, gaskets etc. A true all in one package with everything you need and nothing you don't.
At the very least you can talk to them about what options are available for you and price. For example: https://www.fuelmotousa.com/i-231017...-bore-kit.html
Jim
