Slip-ons keep slipping off....
Old Aug 7, 2007 | 07:50 AM
Wags1's Avatar
Wags1
Default RE: Slip-ons keep slipping off....
Make sure that the slip-ons you are using are the right ones for your header pipes. The ID of the slip-on pipe where it goes onto the header pipe should match the OD of the header pipe.
1. Use a new set of HD TORCA clamps.
2. Run a small bead of high temp gold gasket goop (technical term) around the inside end of the slip-on where it will fit over the header pipe.
3. Position the clamps so that the back edge of the clamp (toward the engine) lines up with the back edge of the slip-on.
4. Tighten the TORCA clamps to 60 ft-lbs.
sulli
2014-2024 Touring Models
16
May 16, 2017 12:34 PM
WVNightster
Sep 19, 2011 06:45 AM
sgtdave
Jul 26, 2009 05:07 PM
antman27
Apr 27, 2009 09:47 AM
falsealarm
Jul 4, 2007 01:29 PM
