Remove both wheels on jack
Old Nov 18, 2021 | 03:32 AM
  #41
Mongo1958's Avatar
Mongo1958
Originally Posted by Rob406
I need to remove both wheels to bring in for new tires. I have the blue HF aluminum jack and have had both wheels off individually, not at the same time. I usually take the seat off and run a ratchet strap over the bike and tie to the jack. I usually position the jack so one wheel stays on or close to the ground. This time i will have to jack from the middle and will probably have to lift the bike pretty high as well.
Has anyone had both wheels off using this method? Is there any added precautions i should take?
Buy an extra rear wheel. I got one cheep for my 09 FLHTCU. Always keep a new tire on it and swap it out when you need it. Makes tire changing a bit easier for me to do one at a time.
BTW I have Pit Bull Lift.
Old Nov 18, 2021 | 05:18 AM
  #42
HD_noobie's Avatar
HD_noobie
Originally Posted by foxtrapper
I think he’s misunderstanding the confusing labeling. The jack is rated for 1500, not simply the hydraulic cylinder. If the hydraulic cylinder were rated or limited to 1500 lbs, it wouldn’t even lift his Victory.
Hydraulic cylinders are very geometric with regards to lifting power. The 4 ton cylinder he’s hoping to use looks geometrically identical. And on the jack, 1500 lbs lifting force is about the max capacity it would have with the arm geometry.
Agreed, He is using the same jack. Force = Area x pressure
Old Nov 18, 2021 | 05:27 AM
  #43
Notgrownup's Avatar
Notgrownup
I have a cheap jack and lifted my bike many many times to remove both wheels at the same time, no problemo
Old Nov 24, 2021 | 07:45 AM
  #44
vette's Avatar
vette
Originally Posted by Bald Eagle
I have the old yellow HF jack and never had an issue with the VTX. I also have a U-Shaped stand I can put under the bike and lower it onto from the stand.
That u shaped stand I was thinking of something like that . Any chance u have a couple pics of it or maybe where you got it from Thanks Joe
Old Nov 24, 2021 | 10:47 AM
  #45
LQQK_OUT's Avatar
LQQK_OUT
Are you referring to a motorcycle dolly?
https://www.redlinestands.com/catalo...e-dolly-p-1248
Old Nov 24, 2021 | 11:01 AM
  #46
julesdain's Avatar
julesdain
Veteran: Canadian Forces
Must be luck of the draw as I've had a Canadian Tire jack for the last 14 years and never had a problem with it.
Old Nov 29, 2021 | 07:33 AM
  #47
vette's Avatar
vette
Exactly Thanks
cmc seabee
Mar 2, 2018 02:37 AM
android75
Wheels/Tires
Apr 21, 2017 08:52 PM
big papa AZ
Mar 3, 2017 07:34 AM
jackod
Wheels/Tires
Jan 13, 2014 09:53 PM
dyna-rider
Sep 13, 2010 11:23 PM
