Oil temp sensor
Old Jul 1, 2021 | 07:53 PM
Stick74's Avatar
Stick74
Stage III
Originally Posted by Stick74
I have a 2012 EG Ultra Ltd. I too am replacing air temp gauge with oil temp gauge. Instructions say to locate connector 107 (air temp sensor). "Connect the 3-way end of the (new) harness from the kit to the mating connector at location 107." In my repair manual, connector 107 is pointing at the back of the fuel gauge, which doesn't help much. I cannot see anything that has a connector that would match up with the connector on the new harness coming from the oil temp sensor. Can you point me to where the #$%^&! air temp sensor is located? TIA
Never mind, located it, as pictured. The white plastic block is pretty well hidden inside a black plastic housing.
Picture snipped from https://serviceinfo.harley-davidson....7?locale=en_US
Old Jul 1, 2021 | 08:02 PM
Buckeye bagger's Avatar
Buckeye bagger
4th Gear
stick, I finally got so frustrated I made an appointment at local dealer to figure it out on Tuesday morning. I’ll send a pic when it’s completed
Slingshot56
Nov 6, 2019 10:29 AM
83wilson
Feb 18, 2017 01:50 PM
nukie2000
2014-2024 Touring Models
Jun 10, 2015 10:05 AM
Flintshooter54
Aug 5, 2011 02:53 PM
FLH05
Apr 4, 2010 11:26 AM
