01 RK Starter Issue
Old Jul 10, 2021 | 09:34 AM
Mrcrx1991's Avatar
Mrcrx1991
Stage I
Default 01 RK Starter Issue
I am gearing a click followed by nothing else. I have installed a direct drive button to the starter but all it does is makes me lose all connection. I have chased power everywhere. I have jumped direct from the battery. And yet nothing will engage the starter! Help please.
Old Jul 11, 2021 | 07:10 AM
MyFavRk's Avatar
MyFavRk
First make sure your getting 12v to the single wire at the starter , remove the connector and test voltage by pressing the start / run button ( ign on ) on the handle bar , it should only show voltage when pressed . If all is good , sounds like a bad solenoid , you can pull the solenoid and check the two surfaces for wear , weak batter / poor connection can cause it to pit / arc , causing a loss in function to the starter clutch .
You may need a replacement kit , but you could try cleaning both surfaces with some emery cloth and see if that helps .
Now , if the " click " is the solenoid fully engaging , then there's a chance the starter clutch is shot and needs replacing .
Hope this helps , and welcome to the forum !
Old Jul 11, 2021 | 07:12 AM
glasspilot's Avatar
glasspilot
After all that it's time to suspect the starter itself!
Old Jul 11, 2021 | 07:16 AM
Hoginedgewood's Avatar
Hoginedgewood
Pull the battery, charge it fully then have it load tested. When you get home follow the ends of those 2 cables, remove inspect and clean them. Reassemble and ride.
so you're magic button mounts to the selonoid, engages the selonoid and starter?
Old Jul 11, 2021 | 07:18 AM
MyFavRk's Avatar
MyFavRk
Here is a video that should help give you an idea of what I'm talking about .
Old Jul 11, 2021 | 07:30 AM
Stiggy's Avatar
Stiggy
If it turns out to be the starter itself, I was my own guinea pig and bought a new Ebay starter for $126 delivered about 7 years ago. I suspect it came from the same manufacturer as everyone else's. Redardless, it works just fine in my '00 95" Road King. (With the direct solenoid bottom installed and still not working, I suspect you'll want to replace it anyway (particularly if it's the original 20 y.o. part.)
Old Jul 11, 2021 | 07:36 AM
glasspilot's Avatar
glasspilot
MyFavRK, Great video!
Old Jul 11, 2021 | 07:42 AM
MyFavRk's Avatar
MyFavRk
One of my bookmarked videos , really does give you an idea of what's going on inside the starter . once you get into it , it's not that difficult . The starter clutch is pretty easy to replace as well , couldn't find the video I've seen on the forum , maybe someone here might post it .
Old Jul 11, 2021 | 07:47 AM
Stiggy's Avatar
Stiggy
When starter clutches go, the starter motor spins freely. (I don't think that's where his problem lies.)
Old Jul 11, 2021 | 07:52 AM
MyFavRk's Avatar
MyFavRk
Agreed , doesn't sound like it , I'd start with the solenoid , checking the voltage first .
luckysroom269@yahoo.com
Jun 21, 2021 03:24 AM
goose1169
Jul 15, 2013 05:29 AM
pd76
EVO
May 7, 2012 07:22 PM
shiznits75
May 20, 2010 12:33 PM
lennox5024
May 23, 2006 02:21 PM
