Compression Releases
Old Aug 7, 2007 | 06:16 PM
Biggzed's Avatar
Biggzed
Default RE: Compression Releases
Finally the real Steve comes out. I've enjoyed reading your past build project updates. I can't wait this one to start. Do I hear 115/115?
Old Aug 7, 2007 | 08:15 PM
maineultraclassic's Avatar
maineultraclassic
ORIGINAL: Biggzed
Not sure what I'm going to do. Might stick with the 0034G's, but bump up the compression to around 10-1 and put in the releases. The 0034's have a lot of potential with added compression, they have a chart on the HQ site of them with around 10.5-1 and it puts out a lot of power.
Steve
Old Aug 8, 2007 | 03:54 PM
maineultraclassic
I wonder if replacing the stock battery cables would help at all?
I can get the "yooper" cables for $39 for the set, supposed to make a big difference in the current flow to the starter.
Steve
Old Sep 30, 2007 | 11:29 AM
maineultraclassic
I was looking at the Spyke bolt-on compression releases, but it doesn't look like they are made for the Twin Cam heads. Does anyone know if they will work with the Twin Cam heads, or are they only for Evo & Shovel heads?
I recently measured my CCP, and it came in at 190 f/r on a luke warm engine.
I'm happy with my build, but the hard hot-restarts are driving me nuts.
Steve
Old Sep 30, 2007 | 11:53 AM
SubZer0's Avatar
SubZer0
Before you go through all of this, have you checked the battery? It could be a cell going bad.
Old Sep 30, 2007 | 08:59 PM
maineultraclassic
Battery is fine.............and all cables are tight.
It's hot restarts.................heat soaking. I need to release the compression on the restarts........that's why I'm looking for compression releases.
Steve
Old Sep 30, 2007 | 11:33 PM
dawg's Avatar
dawg
Shoulda told me, I woulda taken out my yooper cables on the old scoot before I traded it in Do I see a Northeast build party in the works? I'm in the works of putting together my list of toys for my build! The list is easy, the money is the hard part[]So far I'm at HQ575's and JE forged pistons that I want to go with[&:].
Old Oct 1, 2007 | 01:28 AM
hogbag07's Avatar
hogbag07
Double up the earth - battery cable and a thickerpositive + this will give the starter more life
Old Oct 1, 2007 | 05:27 AM
maineultraclassic
ORIGINAL: dawg
If I would have know you were trading in..................LOL
I'll figure something out this winter, bigger battery, new cables, compression releases.................who knows.
Steve
Old Oct 1, 2007 | 05:37 PM
103FLHX's Avatar
103FLHX
I had Compression releases installed at build. Even with this, went through a HD 1.4kW starter.
I think some of the problem was timing as well. Used HD race tuner (carb) & a 1.7kW starter.
No problem since. Starts every time without hestiation. been 2 years.
For what its worth.
103
PS although I have a 103, my comp is 9.7:1, I believe.
