Dredded ripped rear wires from lowering
Old Sep 2, 2021 | 09:29 AM
MikieT's Avatar
MikieT
Default Dredded ripped rear wires from lowering
The 2007 streetglide tire bottom out wires blues!! HELP
the dredded lowering kit ripped wires to rear !
Ok, I replaced, rewired all 6 wires and rerouted, used the new heat shrink soldered connectors, matched all, it's good! Blew (2) 15 amp fuses, replaced, got my signals back, and front brake handle lights brake light, DONT have tail light and foot brake light??
I have power (orange white wire) to that back plug for tail assembly, from new wiring harness created, still no tail light, I jumped the rear brake pressure switch with the constant power wire, ( Bottom wire to top post) as I depressed foot brake,, and no brake light, so I'm getting new pressure switch, but still don't know why I don't have tail? Bulb is good,
is there a module or something else?
Anyone go through this???
Thanks
(edit) if blue wire is for tail, I have no power from front plug, what would cause this/ blow somewhere else?
Old Sep 2, 2021 | 09:34 AM
kel03's Avatar
kel03
Check your grounds.
Old Sep 2, 2021 | 09:40 AM
Pkman's Avatar
Pkman
If the wires were ripped loose they might be broken at the connections at either end
Old Sep 2, 2021 | 09:50 AM
MikieT's Avatar
MikieT
rewired , it was in center of harness the wires shredded,, plugs are good at both ends
thanks
Old Sep 2, 2021 | 10:01 AM
decencyxdefied's Avatar
decencyxdefied
dreaded
Old Sep 2, 2021 | 10:27 AM
MikieT's Avatar
MikieT
If blue wire is for tail, I have no power in front plug that feeds rear wiring harness plug, what would have blown to prevent power to blue wire for tail?
Old Sep 2, 2021 | 11:07 AM
V-Twins & Bowties's Avatar
V-Twins & Bowties
Running lights.
Old Sep 2, 2021 | 11:10 AM
MikieT's Avatar
MikieT
Have no running lights, are you saying blue is for running/tail lights?
Old Sep 2, 2021 | 11:16 AM
smitty901's Avatar
smitty901
Some where here I have 2007 Touring bike Service manual with Electric on CD I need to find it seems like you could put it to use.
Old Sep 2, 2021 | 05:48 PM
Vernal's Avatar
Vernal
Didn't realize you had more than 1 post going on the same subject.
I posted a reply in the Electrical section.
