Kinda makes you wonder if the changes were all done simply because someone screwed up and had to post the issue on the internet. I do believe that the finer tooth count and a possible adjustment smaller tension spring travel was the result of the early tensioners ratcheting too tight. Also the reduced number of teeth on the block helped the tensioner ratchet when it needed to. Otherwise, since it is submerged on oil, the teeth would have issues separating.
I read an article years ago that was discussing the changes made between the auto tensioner versions. The early one flexing, was mentioned as one of the possible factors to the tensioner ratcheting too tight. I don't remember if they said how they came to that conclusion.....
Does not sound like many here like the Baker adjuster. I removed the primary cover this morning and my chain is adjusted correctly and nothing looks to be out of the place. I will fashion up and oil defector out of cardboard so i can start the bike without slinging oil everywhere to watch and listen while it's running. I will report back after i have a better idea of what's going on.
I just had the bike running and it sure seems the comp. is noisy. But i think it's been noisy since it's be new. Not making any noise when starting or shutting it off, yet . I am going to button it back up and add new oil and ride until it gets bad. I guess it's time to turn up the radio.
What damage did this create ? Got any pic's ? How wonder how common this is ?
Thankfully, I caught it early enough that it didn't damage anything. It hadn't come all-the-way loose and get caught in the basket or sprocket, but had that been the case it could have been very ugly - not just in terms of damage, but I've seen where others have had a clutch basket break apart, and grenade everything, including the cases. And when that happens, it can also lock up the rear wheel!
I was about 2 months out of warranty but I did still contact them in hopes that they might extend some good will or at least a discount on a new unit. It also had less than 5k miles on it.
That wasn't the case, nor did they offer any comment on the failure itself.
Though it's a simple piece to replace, it's still a PITA to pull the primary cover, make a mess with fluids, etc. Those factors were all under consideration and led me to replace the tensioner with the updated OEM version.
