Primary chain adjusters
Could be that i rode all day and never turned the radio on and just got dialed into all the noises. No other noise anywhere . Maybe i should just turn the music up. I was thinking maybe switching to Harleys new primary gear oil and see if that helps at all. What do you guys think ? THANKS !
I might just pull the cover and take a look.
In 2010, HD upgraded the auto primary chain tensioner #39939-06A to the #39939-06B. The upgraded "B" tensioner had several upgrades that made it far less troublesome than its predecessor. Some of the changes: thicker base (less flex), smaller ramp teeth (smaller incremental changes), and the shoe ramp reduced the amount of teeth. These changes improved its performance. Not bullet proof, but far fewer issues...
I ran the OEM auto tensioner ("B" tensioner) on my 2016 bagger after adding a 124" S&S engine at 135HP & 151TQ. It handled that power with no problem. I only changed it out because I went to a smaller engine sprocket and went with a tensioner with a different size tensioner shoe, rather than adding a second, snap-on shoe to the "B" tensioner shoe....
Here is a comparison between the "A" tensioner (problematic tensioner, on the bottom) and the newer "B" tensioner (far fewer issues, on the top)..
I'd definitely open up the primary and take a look... You can reuse the cover gasket as long as you are careful taking it off and it's not damaged in the process. I have had my primary cover off 3 times on the same gasket. It's still on there with no leaks...
NOTE: Currently, the "B" tensioner has been superseded by the 39929-06C tensioner. Not sure if there were additional changes to the tensioner, or it's just a vendor change, etc....
I wish I knew....
However it happened, it's obvious the newer version will be less prone to flexing than the older version...
I "borrowed" this pic from a post long ago, because I believe it does a good job of showing the differences between the two versions...
