Trask checkm8 vent
Old Sep 12, 2021 | 02:45 PM
Road2020turbo's Avatar
Road2020turbo
6th Gear
Default Trask checkm8 vent
Hi
i have 2020 road glide with 128 turbo stage 2 from trask performance.
i have an issue that i fixed the checkm8 trans vent and while riding oil starts to come out from the breather continues on high rpm .
i removed it and put on my other bike road 2020 with scremin eagle 131 engine and its working fine without oil coming out .
any one have idea or faced same issue .
regards
Old Sep 12, 2021 | 03:50 PM
Hawg Runner's Avatar
Hawg Runner
Using the same gasket?
Old Sep 12, 2021 | 03:54 PM
Road2020turbo
6th Gear
I tried both the original and the new one came with trask cover same .
Old Sep 12, 2021 | 04:03 PM
Mofo67's Avatar
Mofo67
Oil overfilled on the turbo bike? It is normally recommended to run a M8 build in the middle of the full/low line on the dipstick when hot.
Old Sep 12, 2021 | 04:06 PM
Road2020turbo
6th Gear
Default Turbo
Trans oil its lower than half and still when i push it on high rpm oil will come out .
Old Sep 12, 2021 | 04:07 PM
Road2020turbo
6th Gear
Default Turbo
Not sure but i think there is something wrong why is engine pressure going to the trans oil .
Old Sep 12, 2021 | 05:17 PM
dawg's Avatar
dawg
https://www.hdforums.com/forum/milwa...l#post20107689 this post shows an instructional sheet from Trask about the seal, but yours is a 2020 so it should already have the right one.
Hawg Runner
Hmm! Got me, but would like to know why also.
Old Sep 12, 2021 | 05:20 PM
Quik's Avatar
Quik
Original as in OEM? If so, the oem gasket has the crank section sealed off with defeats the purpose of the check M8
Old Sep 12, 2021 | 05:43 PM
Road2020turbo
6th Gear
Yes oem
i tried it on my other bike and its works fine no oil coming out .
its not the checkm8 vent cover problem , its some other issue .
